Author Topic: Fitting a 3" maf sensor .. Help ?  (Read 1846 times)
Offline p4sty
« on: 17 July 2012, 16:11 »
Hi
Just wondering does the s3 maf fit straight onto a golf mk4 1.8t agu ??
Or does the plug have to be changed ?
Thanks
Offline DunnDeal12
  • Limited
Re: Fitting a 3" maf sensor .. Help ?
« Reply #1 on: 17 July 2012, 16:38 »
no, different plug you need the vr6 or custom one.
Offline jamie1989
« Reply #2 on: 17 July 2012, 16:38 »
I think you have to remove the sensor and swap it out with your 1.8t one.
Thats what Iv done with my vr6 one.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline brianpologti
« Reply #3 on: 18 July 2012, 12:30 »
Depends on ur engine code ,
Offline Dalo Harkin
« Reply #4 on: 18 July 2012, 12:48 »
+1 from what I have read
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 18 July 2012, 17:46 »
AGU - VR6 housing with AGU sensor  :cool:
Offline p4sty
« Reply #6 on: 18 July 2012, 22:00 »
Right so I need a vr6 maf and an agu maf ( as I don't have either ) then ??
I take it I just un screw the 2 screws by the plug on both and then put the agu sensor on the vr6 maf ?
Also isn't the vr6 maf the same as an s3 or lcr maf ??
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 18 July 2012, 22:06 »
how come you don't have either? Just use your current one with a VR6 housing
and no they aren't the same
Offline Chris.
« Reply #8 on: 18 July 2012, 22:51 »
You need a 2.75ID one.  WAs sensors over so 1.8T sensor is in VR6 housing.
Click For Build Thread
Offline p4sty
« Reply #9 on: 19 July 2012, 09:51 »
Because I bought the car half stripped so quite a few things were missing ..
Right I'll order a vr6 maf and an agu one aswel then :-/
Cheers peeps
