Author Topic: Spare Key price VW  (Read 1441 times)
Offline funk3y
Spare Key price VW
« on: 16 July 2012, 18:53 »
Only getting one key with my golf, and Im thinking of getting a second incase i lose it.
How much would a spare cost from vw?
Offline Giro
Re: Spare Key price VW
« Reply #1 on: 16 July 2012, 19:38 »
£130 FOR THE FOB
£80 PLUS VAT TO PROGRAM FROM THE MAIN DEALER IN CARLISLE,CUMBRIA
i have just got a new fob and programed from a lad my friend new who does key cutting for £120, miles cheeper than the main dealer
and the fobs are genuine but not from the main dealer
and he can get the key code from his system they use
if you could get a fob and key cut you could find some one wid vag com to program it to your car for cheaper
Offline Chris#101
« Reply #2 on: 16 July 2012, 19:38 »
Last time I checked around £100ish +/- for just a standard key and £200ish +/- for a key fob
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Chambo
« Reply #3 on: 16 July 2012, 20:04 »
If you want it just for a spare key you can go to timpsons or some other shoe repair/key cutters they will cut you a key,chipped that will work but wont be a remote key so will need to lock/unlock at the door but on the upside they will only charge you £25,a friend popped in the other week on my behalf and they said they can do 90% of VWs.
Chambo
Offline Giro
« Reply #4 on: 16 July 2012, 20:15 »
Chambo
would they not set the alarm off tho? i had a problem wid my focus when i tryed this something todo wid the dead lock??
Offline Dalo Harkin
« Reply #5 on: 17 July 2012, 07:31 »
If it does set the alarmoff it should only be until you put the key in the inition and turn to fire it
Offline big stevie
  • "what doesnt kill me makes me stronger"
« Reply #6 on: 17 July 2012, 10:23 »
i have no remote key at all and im going to give these guys a wizz, key will cost me £50 and £40 to program i just have to get a blade cut but thay will put on auto windows and can do the needle mod and all the other goodies you can add aswell, i want my remote locking so bad one thing that always pisses me off was the alarm going off and hated having to put key in the ignition in case i turned my back and someone drove off in it, after my holiday most defo my next spend on my golf. :smiley: :smiley: :smiley:
http://www.vagwerkes.co.uk/
black 5 door 18t aum engine with 19" lm reps and homemade induction, awesome forge 007p,pressed plates, pillar mounted boost and voltage gauge.
