Poll
I have a stage 2 remap with a Ko3s turbo and an upgrade large FMIC, I dnt think my MAF is getting enough air into the engine can some point me in the right direction? I have heard an 99 RS4 MAF is a straight swap and will get enough air through the engine
Help needed urgent
1 (50%)
MAF Help needed
1 (50%)
Total Members Voted: 2
Author Topic: Mk4 gti turbo MAF  (Read 1187 times)
Offline Turbo Joes Mk4
Mk4 gti turbo MAF
« on: 14 July 2012, 14:31 »
Really need some help on this one
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Mk4 gti turbo MAF
« Reply #1 on: 14 July 2012, 15:29 »
what engine code? I have a stage 2 AGU with the same as you and it's fine. The later MAFs can see more air so that won't be a prob either
« Last Edit: 14 July 2012, 19:10 by Wazzzer »
Offline Chris#101
« Reply #2 on: 14 July 2012, 15:34 »
Whats making you think your not getting the correct air/fuel ratio?
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
« Reply #3 on: 15 July 2012, 09:20 »
The code is AUG I was told it maybe the MAF coz when boosting it starts to lose power higher in the revs, but sometimes it's like the boost doesn't even kick in?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 15 July 2012, 09:22 »
You need to have a look for fault codes, also do some MAF logs
