Author Topic: a rattel can Q  (Read 3648 times)
Offline godsANGER
  • The black Money PIT - TDi ARG MONSTER! lol
a rattel can Q
« on: 12 July 2012, 15:41 »
oks i ve decided to spray my 4Mo splitter, as its textured and its been thought the wars i am sanding it that using filler primer then sanding that then primmer then paint etc but just got a q or two.
are all Filler Primer Spray Paint yellow or can you get them in a different colour?
is wet and dry the best sandpaper to use to smooth the bumpers texture off ?
and whats a good but cheapish bumper/spiltter filler as there are some bad scrapes and a bit of damage towards the wheels?
Thanks
mike
Repairs Since 12/09 = £1860.00  *  Follow me on INSTAGRAM = w_all_ace
! thePOORmansBUILD !
Offline tweed
Re: a rattel can Q
« Reply #1 on: 12 July 2012, 17:34 »
I use a White high build primor. Ain't that the point so you don't have to sand the splitter?  :huh:
Spray on, sand flat. might need two coats.
I'm no expert by any measure but I wouldn't use filler on a splitter. One knock and it will crack. Can't you get a two pack plastic type stuff? Or is that what you mean?
Offline Neo Badness
  • Feet are for pedals
Re: a rattel can Q
« Reply #2 on: 13 July 2012, 12:42 »
There are numerous ways to do this, but I'd do it this way.
Don't use 80 grit on plastic. Use 120 grit for reducing the the appearance of the texture. You get proper bumper filler, such as BMC (it's grey/black fibrous stuff) that will actually stick to the bumper. Normal body filler will too if your doing it rough but won't stand up to much abuse before cracking and falling out. BMC or similar has flex properties like the original substrate so imo better bet.
You might want to apply a surfacer to it to promote adhesion. High build primer comes in variety of colours, grey/ yellow being common. You can get it tinted though for ease of cover up. If your painting it black, grey h/b primer and black has excellent coverage properties.  Rattle cans are ok if you don't have equipment but it'll never be as good as 2k.
Offline godsANGER
Re: a rattel can Q
« Reply #3 on: 13 July 2012, 16:49 »
thanks, yer i meant the bumper filler.
so gray h/b filler should be ok.
Offline godsANGER
Re: a rattel can Q
« Reply #4 on: 13 July 2012, 16:50 »
thanks, the bumper has been thought the wars so thought giving it a good sand would help the finish
Offline Neo Badness
Re: a rattel can Q
« Reply #5 on: 13 July 2012, 21:57 »
No bothers, yup grey will be fine. Key to a good finish is prep :nerd:
Offline godsANGER
Re: a rattel can Q
« Reply #6 on: 16 July 2012, 11:32 »
Thanks Neo,
