Author Topic: 16486 code  (Read 7371 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: 16486 code
« Reply #20 on: 14 July 2012, 15:30 »
just be careful if you do. I've just cleaned the spare MAF I got off Jamie with some electrical contact solvent cleaner from Maplin
Isopropyl alcohol is meant to be the best thing apparently
that rings a bell for some reason, probably in some household cleaner lol
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
Re: 16486 code
« Reply #21 on: 14 July 2012, 16:12 »
I cleaned the MAF with the Halfords stuff, and so far so good. The red bit on the metal wire frame was a bit of red stringy fluff. I pulled it out with some tweezers without touching the metal wire frame!
I have cleared the codes, all three of them, as I had the infamous 17705 code come up since last check. So now I am going to go and sort it, as I do believe the boost issues are related to the T piece on the N112 valve, which leaves one of the ports open on the valve (because I snapped it  :angry:) But now I just received my new N112 valve and I am off to fit it  :smiley:
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: 16486 code
« Reply #22 on: 14 July 2012, 19:17 »
careful then  :laugh:
My mate did the same though
Re: 16486 code
« Reply #23 on: 15 July 2012, 06:42 »
Its a bloody expensive part at £67 to break isn't it. I had to get mine off Ebay for £20. Still have not fitted it yet as it kept raining, so I just drilled and smoothed my air box instead  :smiley: i think I will start on it soon this morning before the rain comes  :laugh:
