Author Topic: 16486 code  (Read 7360 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
Re: 16486 code
« Reply #10 on: 13 July 2012, 13:08 »
Should this red thing that the green arrow is point at, be there in/on the metal wire in the MAF??
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline Dalo Harkin
Re: 16486 code
« Reply #11 on: 13 July 2012, 13:11 »
cant see it too well, remove the sensor from the housing via the 2 screws and slide the sensor part out
Re: 16486 code
« Reply #12 on: 13 July 2012, 13:12 »
Thanks, Ok will do, then i will take another picture!
Re: 16486 code
« Reply #13 on: 13 July 2012, 13:18 »
What type of screw thing is it?? I don't seem to have anything that fits it!
Offline Dalo Harkin
Re: 16486 code
« Reply #14 on: 13 July 2012, 13:23 »
Its like a hollow hex key
Re: 16486 code
« Reply #15 on: 13 July 2012, 13:48 »
I have not got one of them. I just drove down to Halfords and asked there, but they don't sell them!! i shown it to the manager there and he thinks its just a piece of fluff, that is caught on the metal wire plate. He told me to blow it through with an air compressor!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: 16486 code
« Reply #16 on: 13 July 2012, 14:17 »
just be careful if you do. I've just cleaned the spare MAF I got off Jamie with some electrical contact solvent cleaner from Maplin
Offline Dalo Harkin
Re: 16486 code
« Reply #17 on: 13 July 2012, 14:17 »
Well I cant see it on the pic, but when I dissected one it did have a casing around one of the wires that was red
Offline Dalo Harkin
Re: 16486 code
« Reply #18 on: 13 July 2012, 14:18 »
Isopropyl alcohol is meant to be the best thing apparently
Re: 16486 code
« Reply #19 on: 14 July 2012, 10:41 »
I went and got some electrical contact cleaner from Halfords, and the manager shown me on the computer the review that it was good for cleaning a MAF.
Hopefully it will work!
