Author Topic: Cannot get into 3rd gear.  (Read 1475 times)
Offline Ben_
« on: 11 July 2012, 12:59 »
I got into my car after work yesterday and after pulling away found out that my car would not go into 3rd gear, it had been fine on the way into work. I released the clutch and pressed down again but still no luck. All the other gears were fine.
It has now started to get a bit more difficult to go into all the other gears, i'm having to force them in.
Is this likely to be the clutch, gearbox or gear linkage that has gone?
Thanks
Offline Luke1981
Re: Cannot get into 3rd gear.
« Reply #1 on: 12 July 2012, 19:27 »
I would say its the gear linkage by the sounds of it!
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline OhhFK
« Reply #2 on: 14 July 2012, 00:14 »
mine does this and then other times its fine, i just WD40/grease the gear stick base regularly (dont know technical name  :drool:)
