Author Topic: boost spike prob??  (Read 1838 times)
Offline wolfie1981
boost spike prob??
« on: 11 July 2012, 12:47 »
had my car remaped about month ago once done the car boost at 18psi. since having the car done i have not really gone far in it but yesterday done a 200 mile round trip now the car seems to only boost to 14psi and settles at 12psi.
the weekend i fitted a CAI could this be the prob???
i have agu 1999
no fault codes
checked all pipes cant see any leaks if this helps
Offline Dalo Harkin
Re: boost spike prob??
« Reply #1 on: 11 July 2012, 12:50 »
I doubt fitting a CAI would do anything unless you havent attached it properly  :tongue:
In all honesty, just check and re check something has obviously changed somewhere - remember boost leaks leak oil  :wink:
Offline cullygti
« Reply #2 on: 11 July 2012, 12:59 »
should be boosting to 18-20 holding at 14-16 so more than likely got a leak somewhere
Offline dom
  • Back in a Mk4
« Reply #3 on: 11 July 2012, 18:03 »
This, a leak is most likely :wink:
Offline wolfie1981
« Reply #4 on: 11 July 2012, 18:46 »
had a run out this afternoon for a play lol
should you get the boost spike in every gear???
im getting 12 to 14 psi in 1st / 2nd & 3rd around 4000rpm and in 4th if i put my foot down im hitting 18psi and then it drops and holds at 16psi is this about rite?? or should it be 18psi every gear
Offline dom
  • Back in a Mk4
« Reply #5 on: 11 July 2012, 19:06 »
Sounds about right to me.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 11 July 2012, 19:35 »
no you won't get 18psi in every gear
