Author Topic: Undertray removal  (Read 2124 times)
Offline Joewb84
Undertray removal
« on: 10 July 2012, 19:06 »
Hi, hope someone can help.  I've got a mk4 gti turbo.
Part of my undertray had broken and was hanging down.  I have removed the central piece but the broken section is on the drivers side.  I have removed all the screws underneath that I can see and the tray seems to be loose but I can't get it off.  Do I need to remove anything else or should I just yank it out?  Don't want to pull it too hard in case I break anything.
Offline Steve_PD
Re: Undertray removal
« Reply #1 on: 10 July 2012, 19:56 »
Its now held on by a couple star shaped clip up in the wheel arch. use a screw driver to prise the clips off then give it a good yank and it should come out.
Offline JC
  • Back in the North.
« Reply #2 on: 10 July 2012, 20:00 »
or just use some long grass and reverse gear  :lipsrsealed:
Offline Joewb84
« Reply #3 on: 10 July 2012, 20:48 »
Can you get the star shaped clips off without taking loads of other parts out to get to them?  I can see one of them from under the car.  Can you get it off from underneath or do you need to get to it from above?
I did give some thought into driving it over something to knock it off but I don't think that's a long term solution, lol.
