Author Topic: Is this a 1.8l 16v or a 2.0l 16v ?  (Read 3542 times)
Offline Tornado GTI
« on: 10 July 2012, 02:23 »
Hi All
Could some one please tell me if there is a way to tell visually the difference between a 1.8l 16v and a 2.0l 16v?
here is a photo of the engine
Thanks
Offline Lewy
Re: Is this a 1.8l 16v or a 2.0l 16v ?
« Reply #1 on: 10 July 2012, 03:54 »
The block is embossed with either 1.8 or 2.0.
Offline molegti
« Reply #2 on: 10 July 2012, 10:21 »
Have a flick through the project pages and make a comparism with someone who has done a conversion. I understand the 2.0 litre is a taller block so you should see a difference. If I was a gambling man I'd say that was a very clean 1.8.
If your looking at buying the car then does the seller have a reciept for the conversion or engine. That would be a good place to start if in doubt.
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #3 on: 10 July 2012, 11:30 »
From your pic, that's a standard 1.8.
Offline Tornado GTI
« Reply #4 on: 10 July 2012, 12:54 »
Thanks i will have a look at the block to see if i can see any text. and go over the documents and receipts.
VeeDubGTI16v
« Reply #5 on: 10 July 2012, 14:04 »
You get short block 16v's too, as lewy said look for the stamp, it's on the back
Offline mk2bal
« Reply #6 on: 10 July 2012, 17:58 »
2.0 Abf has crank sensor in the front down near oil filter, though the 2.0 9a / 1.8 kr won't. You could also check the blocks stamp on the front! Kr/9a/abf
Offline Reasty
  • Alpine white valver.
« Reply #7 on: 10 July 2012, 19:55 »
That is a 1.8 16v as stated by the other guys,you can also tell by the inlet manifold as on the 2.0 abf inlet manifold the top half goes further round the engine before it meets the bottom half then the 1.8 kr one does,compare the two and you will see what I mean. :smiley:
VeeDubGTI16v
« Reply #8 on: 10 July 2012, 20:22 »
it could be a 9a or 6a as well
manifold means nothing really as you can run the abf/9a/6a on the kr kjet system
Offline Adam
« Reply #9 on: 10 July 2012, 21:09 »
This^
The only way to check is get round the block and get the number/displacement.
Down Hill From Here.
