Author Topic: What is this for?  (Read 11521 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
Re: What is this for?
« Reply #10 on: 09 July 2012, 14:16 »
Ok, to save starting another thread, I will just add on to this one  :smiley:
Is the pipe that the arrow points to, likely to cause a boost problem if it leaks. It comes from the charcoal canister I think.
Thanks
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline mikemk4gti
« Reply #11 on: 09 July 2012, 15:59 »
Isn't that a fuel pipe?
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
« Reply #12 on: 09 July 2012, 16:29 »
Is it? There is a valve connected to it I presume a NRV, which has a pipe going to the carbon canister
Offline mikemk4gti
« Reply #13 on: 09 July 2012, 17:11 »
Maybe not then. If its a vac pipe and it's broke then yes it could be causing your power loss.
Offline Dalo Harkin
« Reply #14 on: 09 July 2012, 17:22 »
OP, take another pic from slightly further away, looks like what is plugged into it shouldnt be if that makes sense
Offline cullygti
« Reply #15 on: 09 July 2012, 18:02 »
i cant quite make it out either as said take a better pic dude  :smiley:
« Reply #16 on: 09 July 2012, 20:26 »
OK guys, try these  :smiley: This is the where the pipe originates from
and here it is from a little further away
and here is another just for clarification with my finger on the valve that connects the pipe in question to the pipe that goes to the carbon canister
Thanks
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #17 on: 09 July 2012, 21:19 »
if you follow that pipe it goes back to your TIP. It has one way valves in line so won't create a boost leak but could be leaking under vacuum
Do you have any fault codes?
« Reply #18 on: 09 July 2012, 22:18 »
I checked today and I don't have any fault codes at all.
I looked at your "carbon canister delete" thread and seen that you blocked off the part going to the tip, but mine seems different because I can't see how it goes back to the tip. All I see is that it goes underneath the inlet manifold and carries on down below somewhere, unless I have missed something  :undecided:
Offline Dalo Harkin
« Reply #19 on: 10 July 2012, 07:12 »
lookin at the pipes that looks all wrong, that pipe you have arrowed should be connected to the throttle body with a T piece and the other side run up toward the firewall and into the TIP, looks like someone has either done some DIY  :laugh: noticed the blue silicone going into a black pipe is that for a boost gauge?
take lots more pics of the bay from close and far because it looks like someone has connected pipes into things that shouldnt be from the pics I can see  :huh:
