Author Topic: Filtering sub Bass  (Read 1946 times)
foilist2000
Filtering sub Bass
« on: 17 June 2005, 16:22 »
Hi there,
I have fitted a sub amp combination and I would like to filter out the sub bass element that is going to my front speakers (driven by the head unit). Any idea how this can be acheived?
Ta
Jace
Offline S11EPS
  • No golfs here. Only a C63 mercedes
Re: Filtering sub Bass
« Reply #1 on: 17 June 2005, 18:47 »
If your head unit doesn't have adjustable filters you need to get yourself down to a decent ICE shop and by yourself some filters. These are basically little capacitors that filter off sub bass. they are fitted in line between the output of the headunit and the speaker itself.
There are different ones available (for differnet frquencies) and what you pick will be dependant on what speakers you;re running and the frequency at which you're running your sub. I would aim to be filtering anything below 100Hz, definitely not trying to produce anything below 80.
The greatest leveller of them all - the Carousel
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 18 June 2005, 15:17 »
only the top headunits have built in HPF's. Most amps can do that too.
Those filters are another option yes
Mk4 Golf 150PD
Offline Overseer
« Reply #3 on: 28 June 2005, 14:23 »
aye.. my alpine amp has a HPF and LPF..
