Author Topic: BMC CDA and MAF sensors - help please  (Read 3599 times)
Offline tigerj360
« on: 05 July 2012, 23:42 »
Hi guys I have tried the search function and google but can't find this anywhere!
I just fitted my bmc cda to my 1.8T ARZ and I'm well impressed! However I had to blank out the maf to test it as I didn't have the right pipe size I'm guessing, I have gone straight to the bmc and cut out the maf and it's housing.
(excuse the crappy pic)
So what I'm thinking is I have a reducer but I need the right size pipe from the maf housing to the reducer. Does any one know what size pipe I will need from the maf housing to the reducer (they are the same diameter)
Thanks guys!
Re: BMC CDA and MAF sensors - help please
« Reply #1 on: 06 July 2012, 00:18 »
Standard MAF is 75mm, if your kit is the same as mine it will be 80mm.
Offline tigerj360
« Reply #2 on: 06 July 2012, 00:35 »
Sweet thanks Wayne, where's the best place to pick up a bit of 80mm pipe? Home base or does it need to be a certain type?  :smiley:
« Reply #3 on: 06 July 2012, 00:37 »
Any pipe will do the job :smiley:
Offline tigerj360
« Reply #4 on: 06 July 2012, 00:48 »
Thanks for all the help Wayne your a star
Another quick question, what do I do with the other hose which enters the air box? I noticed some people said to put a filter of some sort on it?
You might be able to see it on my pic tucked to the left of the BMC next to the engine cover.
Offline Dalo Harkin
« Reply #5 on: 06 July 2012, 08:45 »
remove the SAI  :wink:
Offline tigerj360
« Reply #6 on: 06 July 2012, 09:39 »
Thanks mate so just completely take that hose off?
Offline shaft69
« Reply #7 on: 06 July 2012, 09:45 »
Standard maf is 70mm, mine 70mm on AUM had to get silicone hose fit 70-76mm fit maf to my 3" velicty stack.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
« Reply #8 on: 06 July 2012, 10:54 »
I put a small breather filter in mine. (less than a fiver on ebay)
Offline tigerj360
« Reply #9 on: 06 July 2012, 11:21 »
Thanks for all the help, does anyone know if it will cause any harm running without the MAF until i can source a 80mm pipe?
