Author Topic: Rcd 510 radio taking long time to start  (Read 1814 times)
Offline N3ldv
« on: 05 July 2012, 23:07 »
Has any one had this problem? When I turn the key once it comes on fine but when I turn on the ignition it goes blank and takes 5-10 mins to come back on? Is this a common fault
Offline ScottA
Re: Rcd 510 radio taking long time to start
« Reply #1 on: 05 July 2012, 23:53 »
5-10 mins not norm but usually a bit laggy for the first few mins while it's booting up
Offline Edi35
« Reply #2 on: 06 July 2012, 07:48 »
Never timed how long it takes to come on probably less than a minute, never really noticed but 5 mins is not right, take it your dealer to get them to take a look. You can reboot them but can't remember how to do this, might work?
Current: GTI Edition 35 Candy White 5dr DSG 19" Glendale, RCD510+DAB, Dynaudio, Storage Pack, Parking Sensors
Gone: Edition 35, GTI Mk6, Edition 30, GTI Mk4, GTI Mk3, GTI Mk2 and my favourite the UR quattro
For those that dont know DSG is an electronically controlled dual-clutch multiple-shaft manual gearbox
Offline dubber36
« Reply #3 on: 06 July 2012, 07:49 »
It shouldn't be doing that at all. It's a bit slow when you press media and it reads all the albums on a usb stick (don't know about an ipod), but I'm only talking about a couple of seconds.
Offline Mr GTD
« Reply #4 on: 06 July 2012, 08:40 »
^^^^this, my RNS does this...it's going into VW on Monday cus it froze on me the other day, it was quite weird cus everytime I went to turn up or down the volume the bar instead of being red wud be blue and the only time it shud be blue if for the nav...thankfully at the time of the fault I was near my dealers so I went there straight away so they cud see the fault in action...this fault has happened previous but as it was a intermittent fault there was no point in telling the dealer....
Offline sundaydriver
« Reply #5 on: 06 July 2012, 08:49 »
Definitely shouldn't do this, did you spec it with the car or did you retrofit it?
2012 Golf R, APR STAGE 2+, BCS power valve TB exhaust, loba HPFP, evoms intake, Rising blue, 19" Talladegas -BMW M2
