Author Topic: 16v conversion  (Read 3802 times)
Offline 67buggers
16v conversion
« on: 05 July 2012, 12:14 »
Right im starting to plan a 16v conversion in my mind, i have a list from murraymints old post of bits i need and also brake upgrade bits...... I have been looking at different engines and saw there are diffrrent engine codes for the 16v . Which is the best one to use?
I fix iPhone's and iPod's, I can fix most faults call me on 07811344816 for a quote
Offline Ess_Three
Re: 16v conversion
« Reply #1 on: 05 July 2012, 12:15 »
There is only one engine code for the Mk3 16v: ABF.
..but gaining motorcycles.
Offline mrsaunders
Re: 16v conversion
« Reply #2 on: 05 July 2012, 12:29 »
maybe you've come across the corrado one?
the abf is the better of two so ive heard
Offline Len
Re: 16v conversion
« Reply #3 on: 05 July 2012, 12:43 »
The Corrado's were 1.8 litres.
www.sas.org.uk
www.the-ace.org.uk
Offline mrsaunders
Re: 16v conversion
« Reply #4 on: 05 July 2012, 12:48 »
pretty sure some came with the 2l 16v 9a engine, could be wrong though
Re: 16v conversion
« Reply #5 on: 05 July 2012, 13:34 »
Your not, later cars were available with the 2.0 16v :smiley:
ABF is still the better choice however
Offline 67buggers
Re: 16v conversion
« Reply #6 on: 05 July 2012, 14:11 »
Nice one, it was a corrado one I just assumed there were a few and fitted to all models. Is it easy enough to do the hydrolic clutch conversion? I'm assuming(again!) that the shell is the same across the board and that the new stuff for the clutch should just bolt in place?
Offline spikenipple
Re: 16v conversion
« Reply #7 on: 05 July 2012, 17:30 »
I think you'll need the pedal box from the 16v.
Re: 16v conversion
« Reply #8 on: 05 July 2012, 21:24 »
What year is your car, later cars had the same pedal box so are easier to convert.
Offline Dogbot
Re: 16v conversion
« Reply #9 on: 05 July 2012, 22:14 »
I you need a pedal box and clutch master & slave cylinders drop me a pm I'm breaking a late ABF model,
