Author Topic: 16v conversion  (Read 3794 times)
Offline 67buggers
Re: 16v conversion
« Reply #10 on: 05 July 2012, 22:38 »
I you need a pedal box and clutch master & slave cylinders drop me a pm I'm breaking a late ABF model,
I'm not ready to do it yet just trying to plan it in my head and price bits up.....
Wayne my car is a 1997.... Does this mean I have the correct pedal just need to swap clutch ?
I fix iPhone's and iPod's, I can fix most faults call me on 07811344816 for a quote
Re: 16v conversion
« Reply #11 on: 06 July 2012, 00:30 »
Yes, you have the later pedal box so the cylinder will just clip on.
Offline 67buggers
Re: 16v conversion
« Reply #12 on: 06 July 2012, 07:49 »
Cheers Wayne......did you design the mk3? You know everything!
Offline 67buggers
Re: 16v conversion
« Reply #13 on: 06 July 2012, 08:22 »
I'm going to up rate my brakes using a combination of mk2 gti hubs and mk3 gti carriers and calipers.....do I need to install ABS?
Offline Dogbot
Re: 16v conversion
« Reply #14 on: 06 July 2012, 09:23 »
Again let me know if you need the cylinders then, I just bought a pedal box & cylinders for my mk2 conversion.... cheapest i could get was £90 from a breaker,....  I'd be glad to see the good parts ive got go to a good home at mates rates dude!!  :wink:
Offline 67buggers
Re: 16v conversion
« Reply #15 on: 06 July 2012, 11:01 »
Pm'd you dude
Offline 67buggers
Re: 16v conversion
« Reply #16 on: 06 July 2012, 15:08 »
Are the drive shafts on my1.4  different to drive shafts on a 16v gti? And are the hub carriers different to a 16v gti.....basically I want to know why I can't just bolt 280mm g60 discs on to my existing hubs and just upgrade my calipers if needed?
