Author Topic: MK4 Gti 2.0 (2000 W Reg) won't start  (Read 910 times)
Offline Adycakes
« on: 03 July 2012, 22:32 »
Hi,
Today my car refused to start, hooked it up to a Vag Com & the following error code was shown:
18034 -  Powertrain Data Bus: Missing Message from TCU
            P1626 - 35-00 -   -
Clearing the code hasn't helped, and googling around doesn't seem to have a solution or at least a consistent one. The car is a manual not an automatic, I have checked the fuses as suggested in another thread, an although the car did start when changing Fuse 15, it hasn't started again since.
My knowledge of cars is limited, but I can follow instructions if there are some. I jut wanted to ask if anyone had any suggestions before calling the AA to tow me to a garage.
Any info would be appreciated, thanks
Ady
Offline pickles
  • Next!!!
Re: MK4 Gti 2.0 (2000 W Reg) won't start
« Reply #1 on: 03 July 2012, 22:56 »
have u checked the basics, AIR, Fuel, Spark
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline Adycakes
« Reply #2 on: 03 July 2012, 23:13 »
Again knowledge is limited, how would one go about testing each bit you mentioned?
Offline pickles
  • Next!!!
« Reply #3 on: 03 July 2012, 23:16 »
forget that, looks like an immobilizer problem :(, http://www.bba-reman.com/content.aspx?content=DTC_P1626
Mapped
Nearly S3 time  :)
