Author Topic: v heavy clutch  (Read 3363 times)
Offline tom67
v heavy clutch
« on: 03 October 2003, 15:35 »
i own a 1997 2.0 gti v clean car well looked after only 36000 on it but have recently noticed the clutch has became very heavy any body any ideas to what may be causing this  ???
i-espedair
Re:v heavy clutch
« Reply #1 on: 03 October 2003, 17:05 »
I quite like a more solid, heavy cluch with a high biting point! But mine has always been alot heavier than anyother cars i have driven. I presumed all VeeDubs were like this. Certainly the ones i've driven have been!!!???
golfvr6
Re:v heavy clutch
« Reply #2 on: 03 October 2003, 23:52 »
The pedal shouldn't be that heavy! i think the gti had a cable clutch, so try changing that first.
Offline tom67
Re:v heavy clutch
« Reply #3 on: 11 October 2003, 16:31 »
thanks for suggestions going to change cable to see if that helps
Offline VWaxilMK1cab
  • 1992 mk1 cabrio gti
Re:v heavy clutch
« Reply #4 on: 14 October 2003, 00:23 »
Not sure if this will be of any help, but...
My biting point is very high also, the clutch isn't that heavy \ stiff, but you only have to press it an inch or two to change gear.
Are these the signs of a golf traight, or jsut both of us having broken clutches?
golfvr6
Re:v heavy clutch
« Reply #5 on: 14 October 2003, 19:26 »
If the biting point is high then the friction plate is worn, if the pedal is stiff then the cable or pressure plate are worn.
Offline modulater
Re:v heavy clutch
« Reply #6 on: 15 October 2003, 03:01 »
Indeed it is, the less meat on a clutch plate the higher the pedal, as you dont have to push it down as far to disengage it.
