Author Topic: Fitting Catch Can  (Read 14296 times)
Offline GTIcheeseman
Re: Fitting Catch Can
« Reply #30 on: 03 July 2012, 10:50 »
Might give it a go lol
Offline Dalo Harkin
« Reply #31 on: 03 July 2012, 10:52 »
For you, I would just get a 90 degree elbow for where the kink is
Thanks, I have one of them. I will do that sometime today and will say later on if it makes a difference or not to the power.
Wont do anything to the power, itll just let it breath better
Offline cullygti
« Reply #32 on: 03 July 2012, 10:57 »
and stops all the crap from going back through your engine  :smiley:
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« Reply #33 on: 03 July 2012, 11:04 »
any1 got any pics of the connection to the oil filter after install by any chance
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
« Reply #34 on: 03 July 2012, 11:06 »
cully where di you get all your bits from?
Offline cullygti
« Reply #35 on: 03 July 2012, 11:25 »
ebay and my 19mm fittings were custom made by an engieering place local to me
« Reply #36 on: 03 July 2012, 11:26 »
ah man lol i need to get a list of what parts i need to get
Offline Dalo Harkin
« Reply #37 on: 03 July 2012, 12:19 »
I was referring to the kink not the catch can  :wink:
I was referring to the kink not the catch can setup  :wink:
Offline cullygti
« Reply #38 on: 03 July 2012, 12:37 »
ooh ok  :grin:
Offline jamie1989
« Reply #39 on: 03 July 2012, 12:40 »
Parts you need -
Ebay catch can about £25 delivered with 15mm outlet/inlet.
16mm pipe - half a meter about £6 delivered
19mm pipe - 2meters about £12 delivered
T peice (19mm) £3 delivered
19-16mm reducer £3 delivered.
The reason I had 16mm pipe is because I struggled to find 15mm pipe and 19-15mm reducer.
Thats all you need.
« Last Edit: 03 July 2012, 12:44 by jamie1989 »
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
