Author Topic: Fitting Catch Can  (Read 14286 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
Re: Fitting Catch Can
« Reply #20 on: 03 July 2012, 07:43 »
Does a kink in the pipe cause much difference at all, as I have one in mine
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline Dalo Harkin
« Reply #21 on: 03 July 2012, 08:42 »
For you, I would just get a 90 degree elbow for where the kink is
« Reply #22 on: 03 July 2012, 08:54 »
Thanks, I have one of them. I will do that sometime today and will say later on if it makes a difference or not to the power.
Offline GTIcheeseman
« Reply #23 on: 03 July 2012, 09:19 »
i got my breather pipe from dealers mate cost close on £30 think they are half that from tps there was a link on here a while back  :wink:
as you can see in my pic i kept getting the kink which is now sorted may be different as i had custom 19mm fittings made
have you got an agu engine code??
Offline cullygti
« Reply #24 on: 03 July 2012, 09:46 »
yes i have mate
Offline pickles
  • Next!!!
« Reply #25 on: 03 July 2012, 09:51 »
any1 got any pics of the connection to the oil filter after install by any chance
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
« Reply #26 on: 03 July 2012, 10:23 »
yes i have mate
how did you do it? i see the guide but thats not for an agu is it?
Offline cullygti
« Reply #27 on: 03 July 2012, 10:29 »
no mate i followed the aum guide and just took it from there it was easy enough tbh and not as complicated as the aum i was going to do a how to but couldnt get the camera where i wanted to take pics so didnt bother  :smiley:
« Reply #28 on: 03 July 2012, 10:30 »
ill have a look maybe someone needs to do one for an AGU lol
Offline cullygti
« Reply #29 on: 03 July 2012, 10:35 »
you cant really go wrong its what you se in the my pic with one pipe going to the oil filter housing after you have removed all the old system  :smiley:
