Golf mk3
hardmonkeys
She'd some light on this problem
Topic: She'd some light on this problem (Read 1061 times)
Stewy12
02 July 2012, 11:25 »
As title am I right in believing the 02 sensor(lambda) is connected somehow to fuse 18 the fuel pump as I keep blowing fuses and have a short some were and check all wiring and all is fine no breaks or shorts...
javalin
Re: She'd some light on this problem
02 July 2012, 16:06 »
seems to be the O2 and FP - so yes.
http://faculty.ccp.edu/faculty/dreed/Campingart/jettatech/techset/index.htm
Might be worth changing fuel filter - blockage could cause additional load on the pump.
When does it blow - whilst driving / engine running? / or just ignition on?
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Golf mk3
hardmonkeys
