Author Topic: golf mk2 top mounts wobbly  (Read 5822 times)
Offline JimR
Re: golf mk2 top mounts wobbly
« Reply #10 on: 01 July 2012, 21:47 »
From memory 8mm
Thom
I have a horrible feeling its 7mm.
Mk2 GTi.
Offline lord14
« Reply #11 on: 01 July 2012, 22:13 »
the top rubber mount can be lifted off
Offline Mr Blue
« Reply #12 on: 02 July 2012, 00:21 »
Offline Mr Blue
« Reply #13 on: 02 July 2012, 00:21 »
Offline beechymonza
  • mad beech
« Reply #14 on: 02 July 2012, 09:24 »
Does the top mounting bush need replacing,  :wink:
Or why dont you take the other side off if thats ok,
And take them apart at same time and see if everything is the same,, :wink:
No guts No glory,
Offline devilscaff
  • allways up for alaugh
« Reply #15 on: 02 July 2012, 10:44 »
It must be 7 cause iv tried 6,8mm neither. Tried everyone I have metric and imperial, 7 is the only one I don't have!!
Offline JimR
« Reply #16 on: 02 July 2012, 11:34 »
You can get a brake key from halfords which is 7mm, I had to buy one when I did mine, that's how I remembered the size, some old Vauxhalls had 7mm hex caliper slide bolts. Such an awkward size.
Mk2 GTi.
Offline devilscaff
« Reply #17 on: 02 July 2012, 14:24 »
Cheers Jim, have to get one as I have a knocking noise comming from that area. Iv checked everything I can but to no avail so it's time ti take the shock off and check my top mount, just when you think your done!!!!
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #18 on: 02 July 2012, 14:27 »
+1 on the calliper bolt key. Bought one from Halfrauds to do my calipers, fits the top mount nut as well.
This one:
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_217824_langId_-1_categoryId_255216
Offline weazgti
« Reply #19 on: 02 July 2012, 16:26 »
That wanky slotted nut kept coming loose on mine no matter how tight it was.
Replaced it with mk3 spring plates and top mounts and a normal nut. Job done, no more messing about with a hammer and screwdriver. They are far superior to the mk2 mounts.
