Author Topic: 3dr Door Sagging  (Read 7779 times)
Offline vik
3dr Door Sagging
« on: 29 June 2012, 18:17 »
What do I need to sort this? I'm guessing some kind of bushes, but I don't have a clue what? Anyone had this problem before who can point me in the right direction?
Thanks!
Offline Thom89
  • Looking for an "Icebreaker"
Re: 3dr Door Sagging
« Reply #1 on: 29 June 2012, 18:30 »
Clear as mud!
Thom
Offline sparkplug
« Reply #2 on: 29 June 2012, 20:13 »
 :smiley:  front or rear ..?
1986 GTI atlas grey
Offline vik
« Reply #3 on: 30 June 2012, 13:49 »
Clear as mud!
Thom
Really? I thought it was all in the title to be honest.
One of the doors, on my three door VW Mk2 Golf GTI, is sagging. What do I need to fix it?
Offline Thom89
« Reply #4 on: 30 June 2012, 14:16 »
Could be any one of about 4 different issues.
Open your door half way, grab hold of the top of the frame and door handle, and lift the door in a up and down motion, if the door has any play, then its most likely the hinge pins need replacing... in extreme cases the hinge mounting points could be rotten, allowing the hinge its self to move... check these areas first
Thom
Offline Jimmyrallye
  • 20vt goodness
« Reply #5 on: 30 June 2012, 19:18 »
I had to have the bracket rewelded on my old mk2 as it had came away
Offline Jimmyrallye
  • 20vt goodness
« Reply #7 on: 30 June 2012, 22:02 »
Haha i do try  :wink:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #8 on: 01 July 2012, 01:33 »
I was told by a MK2 "specialist" body shop that when a door started dropping there was feck all you can do - Based on the basic assumption that both body and door hinges were intact and not moving...
So are you saying that you can knock out the door hinge pin on the door and replace it?
For More Info Click To See;
Offline Thom89
« Reply #9 on: 01 July 2012, 01:55 »
Unbolt door, place carefully on some sort of table/tressel... Then using a heavy drift and hammer, knock the lower pin, in an upwards direction, and the upper pin in a downwards direction, then replace with these... http://www.ebay.co.uk/itm/GOLF-MK1-GTI-MK2-CABRIO-CADDY-DOOR-HINGE-PINS-GENUINE-/251012671218?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a718566f2#ht_1480wt_960
Sorted!
Thom
