Author Topic: 3dr Door Sagging  (Read 7781 times)
Offline X4MGS
  • VAG Parts SNOB!!!
Re: 3dr Door Sagging
« Reply #10 on: 01 July 2012, 02:00 »
I was told by a MK2 "specialist" body shop that when a door started dropping there was feck all you can do - Based on the basic assumption that both body and door hinges were intact and not moving...
So are you saying that you can knock out the door hinge pin on the door and replace it?
Unbolt door, place carefully on some sort of table/tressel... Then using a heavy drift and hammer, knock the lower pin, in an upwards direction, and the upper pin in a downwards direction, then replace with these... http://www.ebay.co.uk/itm/GOLF-MK1-GTI-MK2-CABRIO-CADDY-DOOR-HINGE-PINS-GENUINE-/251012671218?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a718566f2#ht_1480wt_960
Sorted!
Thom
Off to find some and have a go on my door, the wife's and my lads x 2 ....
Don't you just hate owning 4 x Mk2's at times...
Thanks Thom...
For More Info Click To See;
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #11 on: 01 July 2012, 02:13 »
Sorted!
Thom
Thanks Thom...
No worries, we aim to please :cool:
Sometimes... the pin can be difficult to remove, this is usually because the hinge gets hung up on the worn pin, try rotating the hinge into different angles to bypass the worn section, and use lots of WD40
These pins/hinges can also be converted to "Roll pin" type if the OE ones are not available, iirc they are 8mm and are a straight swap for the original item...
Thom
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #12 on: 01 July 2012, 02:17 »
That we do!!
« Last Edit: 01 July 2012, 13:02 by X4MGS »
Offline Thom89
« Reply #13 on: 01 July 2012, 08:56 »
That we do!! - Even if you don't like the person asking the question....
Thanks anyway!!
Nice! :huh:
Thom
Offline clipperjay
« Reply #14 on: 01 July 2012, 09:21 »
Thanks anyway!!
 :shocked:
Jeez Ken ffs Thom helps you, which in my mind only if he likes the person he responds to.
He helps loads of people on here!
What was the point of that? :huh:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #15 on: 01 July 2012, 13:01 »
Sorry It wasn't aimed at Thom....
It was just a general reply....
Quote
That we do!!
The emphasis on WE..
Sorry Thom No Offence aimed at you...
Offline JC
  • Back in the North.
« Reply #16 on: 01 July 2012, 17:55 »
Gotta love edited posts even when the original has been quoted  :grin:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #17 on: 01 July 2012, 18:00 »
Them hinges might be worth a purchase for future  :smiley:
Offline Thom89
« Reply #18 on: 01 July 2012, 19:30 »
Quote
That we do!!
Non taken...
Lets move on
Thom
Offline vik
« Reply #19 on: 02 July 2012, 23:09 »
Are those pins what you can see on the door frame? My door seems to be wobbling from where the bottom strut attaches (inside) the door.
