Author Topic: hesitation  (Read 3124 times)
Offline stainesy
hesitation
« on: 29 June 2012, 11:46 »
i have a hesitation at low revs. in say second gear when drivng off or if i give it some welly it hesitates then finaly gets its power. almost like the turbo lag feeling you used to get on old turbo cars but obviously without the power they have  :grin:
could this be dirty throttle body or something els?
Offline Stewy12
Re: hesitation
« Reply #1 on: 29 June 2012, 11:50 »
Similar to my prob changed pretty much everything and cleaned TB and still got it  :sick:
Offline Luke1981
Re: hesitation
« Reply #2 on: 29 June 2012, 11:55 »
Dirty throttle body was also the first thing that sprung into my mind.
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline Len
Re: hesitation
« Reply #3 on: 29 June 2012, 12:24 »
Maybe ECU relay
www.sas.org.uk
www.the-ace.org.uk
Offline stainesy
Re: hesitation
« Reply #4 on: 29 June 2012, 13:29 »
its a strange one as i just went for a drive and it didnt do it. but this morning and sometimes it does. is there any chance that a slitely blowing downpipe or manifold could cause it?
Offline CJA321
Re: hesitation
« Reply #5 on: 29 June 2012, 13:46 »
Something differant wrong with your car everyday Stainesy  :drool:
Offline stainesy
Re: hesitation
« Reply #6 on: 29 June 2012, 14:42 »
I no but I'm slowly working my way through it all  :grin:
Also since iv fitted the good exhaust I have noticed like a hot smell if you no what I mean. And the exhaust seems very hot all the way to the back and even the chrome tips feel propper hot. Don't remner my other exhaust being this hot at the backbox.
Iv driven golf about before and then worked under them wile they have just been for a long drive and the backbox's where never to hot to touch they were always just abit how.
It could just be coz I have a free flowing exhaust now and the heat is going all the way through ok but thought I would mention it.
Offline javalin
Re: hesitation
« Reply #7 on: 29 June 2012, 15:41 »
could be that the mixture is wrong (i.e. rich) and that is generating the heat in the exhaust.  Would be tempted to look at ignition timing, MAF and Lambda for this type of problem, in that order.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline mrsaunders
Re: hesitation
« Reply #8 on: 29 June 2012, 16:43 »
James
Yeah totally agree I had this, done a scan and it was the lambda sensor, changed it and it was all good after
Offline stainesy
Re: hesitation
« Reply #9 on: 29 June 2012, 18:05 »
ah i see. anybody in luton area with a code reader?
also i have noticed that its a bit of a b!tch to start alot now. turns over and over then struggles to start. then dies. then i try again and it starts fine.
how do i check the ignition timing?
