Author Topic: boost issues.  (Read 3731 times)
Offline monty9120
boost issues.
« on: 28 June 2012, 16:47 »
i had issues when the car was cold. i would accelerate and it would miss and wouldnt go anywhere
i changed the dump valve to a forge 007. the issue was 99% gone
latelly the same symptoms have come back. maybe not as bad but still there. sometimes hesistations through the revs
it doesnt seem to do it when its warm at all though. never has done.
i have checked over as many pipes as possible. replacing any that were abit dodgy.
there seems to be a pss noise like a dump valve in the engine bay. i gather a gentle whoosh is normal. it seems to come from around the injector side but its hard to pin point.
do the valves get noisy with age. my car has got 160k on the clock. its starting to make a weird noise from the cam belt or head area. once revved its not there.
Offline rio_gti
Re: boost issues.
« Reply #1 on: 28 June 2012, 16:55 »
sounds like a split vacuum pipe, might you have missed one when checking??
Offline monty9120
Re: boost issues.
« Reply #2 on: 28 June 2012, 16:57 »
well i have checked as many as possible. especially around the injector area.
how come when fitted the dump valve it stopped? i did find a massive split in the pipe from the head but thats sorted. still no difference
Offline Dalo Harkin
Re: boost issues.
« Reply #3 on: 28 June 2012, 16:58 »
when looking for boost leaks, oil is the easiest give away
Offline monty9120
Re: boost issues.
« Reply #4 on: 28 June 2012, 19:12 »
there is a little around the injectors its always been there
Offline Dalo Harkin
Re: boost issues.
« Reply #5 on: 28 June 2012, 19:34 »
have you replaced the top and bottom o rings on the injectors? you can get boost leaking from there
Offline monty9120
Re: boost issues.
« Reply #6 on: 28 June 2012, 21:22 »
nope any idea what this entails and how i get them off.
Offline cullygti
Re: boost issues.
« Reply #7 on: 28 June 2012, 21:32 »
you wouldnt loose that much pressure from leaky injector seals mine have been fooked for a while and i got full boost  :wink:
Offline bobbieboy69er
  • MK4 1.8T AUM
Re: boost issues.
« Reply #8 on: 28 June 2012, 21:33 »
When your accelerating is the turbo spooling?
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
Offline Dalo Harkin
Re: boost issues.
« Reply #9 on: 29 June 2012, 08:57 »
Get it sorted then  :smiley:
