Author Topic: agu k04 intake pipe  (Read 3940 times)
Offline markgti1.8t
agu k04 intake pipe
« on: 28 June 2012, 02:50 »
hi there can some one tell me if this http://www.ebay.co.uk/itm/360412189272?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_sacat%3DSee-All-Categories%26_from%3DR40%26_nkw%3D360412189272%26_rdc%3D1#ht_1470wt_656   is the rite intake pipe for a k04 turbo if it was on a golf i no its for a k04 but would the pipe be ok for the golf to thanks
« Last Edit: 28 June 2012, 02:55 by markgti1.8t »
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Offline jonrandom
Re: agu k04 intake pipe
« Reply #1 on: 28 June 2012, 05:08 »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 28 June 2012, 07:18 »
Would be good if he made them for the K03s
Offline rio_gti
« Reply #3 on: 28 June 2012, 09:22 »
Is it worth gettin the badger tip if you got the k03 hotside? Would there be enough flow to justify using it?
Offline jonrandom
« Reply #4 on: 28 June 2012, 20:15 »
Yeah defo or a TD05 16G for me!  :grin:
Dont honestly know but more air going through cant be bad! less heat build up?
Offline rio_gti
« Reply #5 on: 28 June 2012, 21:56 »
But it still funnels down at the actual turbo intake so should it really make a difference reducing right at the turbo rather than slowly down the tip to it  :undecided:
Offline jonrandom
« Reply #6 on: 28 June 2012, 22:07 »
Yeah see what your saying and I thought the same but look at the pictures on the item hes got graphs to prove it working and read about it making a difference. Didnt Nick from rtech say that, that TIP with the manifold on Tobys beast enabled him to get over 300bhp
Still alot for a TIP tho but 300 bhp, got to be good!
Offline dmt88
« Reply #7 on: 28 June 2012, 22:15 »
hi sorry to but in but i have a hybrid ko3 turbo with a forge TIP are these as good or would i still benefit from a badger one.
Offline Toby
  • Car - less
« Reply #8 on: 28 June 2012, 22:20 »
The size of the badger 5 tip over a ko3s is huuuuuge!!
To give you some sorta idea
Currently down under
Offline dmt88
« Reply #9 on: 28 June 2012, 22:25 »
see what ya mean cheers for that  :smiley: would it fit onto my turbo?
