Author Topic: Climatronic help. SORTED  (Read 3845 times)
Offline jnufcuk
« on: 27 June 2012, 19:12 »
Anyone know what HE means on the climatronic?
Turn car on, temp comes up and cant adjust fans, after a minute or two temp disappears and HE come up then I can adjust fan speed?
Any ideas  :undecided:
« Last Edit: 29 June 2012, 20:24 by jnufcuk »
Re: Climatronic help
« Reply #1 on: 27 June 2012, 20:37 »
Could be a faulty panel, see if you can get and try another one.
Offline jnufcuk
« Reply #2 on: 27 June 2012, 20:41 »
Bloody climatronic on this mk3, works for about a week then goes tits up  :angry:
Wouldn't mind if they were easy to get hold off.
Think I might have a spare panel will have a look and try. So frustrating. Great when it's working, pain in the a$$ when it's not  :rolleyes:
« Reply #3 on: 27 June 2012, 21:21 »
On the mk4 they have a self test mode, not sure if the mk3 is the same.
VeeDubGTI16v
« Reply #4 on: 27 June 2012, 21:52 »
sounds like your climatronic is sexist
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #5 on: 28 June 2012, 16:28 »
Homo Erotic?
Offline jnufcuk
« Reply #6 on: 28 June 2012, 16:30 »
All very helpful answers  :rolleyes:  :grin:
Tried a different panel and did the same thing. Only way you can turn fan speed down/ up is by putting heat up to full then HE appears. Could it need regassing? :undecided:
Would a blown fuse stop the whole thing from working?
« Reply #8 on: 29 June 2012, 00:31 »
From what Ive just on a couple of different forums it could be worth checking out relay 140 as these can bring up fault codes when duff.
« Reply #9 on: 29 June 2012, 09:16 »
Even if it was out of gas, the control panel should still work as normal.
