Author Topic: Inlet manifold for 1.8t gasket question  (Read 1575 times)
Offline jamie1989
« on: 26 June 2012, 16:44 »
I have got a spare inlet manifold which im having sprayed as we speak, However I removed this for another 1.8t and it didnt have any gasket on there?
Am I right in thinking theres no need of having one unless you put a power gasket there to reduce intake temp or heat transfer?
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline DunnDeal12
  • Limited
Re: Inlet manifold for 1.8t gasket question
« Reply #1 on: 26 June 2012, 16:52 »
yes a gasket is needed
large port 058 129 717 D
« Last Edit: 26 June 2012, 16:55 by DunnDeal12 »
Offline jamie1989
« Reply #2 on: 26 June 2012, 17:53 »
Legend cheers mate.
Offline shaft69
« Reply #3 on: 27 June 2012, 00:19 »
Power gasket really lowers your intake temp, fitted mine a month back. Before fitted it on run couldn't touch intake manifold that hot, now just warm difference is amazing.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline DunnDeal12
  • Limited
« Reply #4 on: 27 June 2012, 08:46 »
power gaskets are over rated my inlet still gets hot.
Offline turbokid23
« Reply #5 on: 27 June 2012, 10:58 »
Sorry for pching the thread,, woulda Audi a4 manifold or a passat 1.8t fit my Aum??
Offline DunnDeal12
  • Limited
« Reply #6 on: 27 June 2012, 13:44 »
yes as long it is small port
Offline cullygti
« Reply #7 on: 27 June 2012, 14:54 »
i may be wrong but dont think i am but isnt the a4 inlet mani from a longitude engine i think its called so wont fit  :huh:
Offline DunnDeal12
  • Limited
« Reply #8 on: 27 June 2012, 15:53 »
sorry didn't read it right lol, no the a4 or passat inlet wont fit a golf as the engines are positioned differently
thought you said would a a4 inlet fit a passat 1.8t
