Author Topic: Cracked Wheel  (Read 2639 times)
Offline gossy
Cracked Wheel
« on: 25 June 2012, 17:51 »
I have currently on my mk3 a set of banded steel wheels, however one has a crack in it, so the tyre is very quickly loosing air, i was just wondering if anyone had any idea of how much it would cost for a garage to weld it, or if its easy enough to do it yourself?
Re: Cracked Wheel
« Reply #1 on: 25 June 2012, 21:00 »
I guess it is easy enough to weld but you need someone to do a top job (coded welder would be better)
Or if your not sure of the quality of the banding then scrap them :smiley:
« Last Edit: 25 June 2012, 23:35 by Wayne »
Offline Thom89
  • Looking for an "Icebreaker"
Re: Cracked Wheel
« Reply #2 on: 25 June 2012, 22:25 »
You have a crack in a banded rim! I know what I'd do with them :rolleyes:
Thom
Offline OhhFK
Re: Cracked Wheel
« Reply #3 on: 25 June 2012, 23:49 »
not sure about steelys but just had my alloy welded for £36.. same problem as you, cracked outer rim im guessing
Offline gossy
Re: Cracked Wheel
« Reply #4 on: 26 June 2012, 08:53 »
Dont really want to scrap them and get a new set as they cost me £300! Might have to do a garage job then
Offline TDIgadge
Re: Cracked Wheel
« Reply #5 on: 26 June 2012, 11:03 »
Engineering shop or fabrication place where they have professional welders, not joe bloggs from the garage
