Author Topic: No Brake Lights!  (Read 1540 times)
Offline Horney
No Brake Lights!
« on: 14 June 2005, 21:06 »
As above they don't seem to be working anymore.
What should I check? Is there a fuse just for these? DO the switches on the peddle have a habit of busting and is it easy to test it?
ANything else to look for as the likely problem?
CHeers,
Nick
Offline ...joe
Re: No Brake Lights!
« Reply #1 on: 14 June 2005, 21:52 »
the switch can get a bit stcky, have a play with it. its a plunger type switch that pops out as you push the pedal so i suppose the plunger could be getting stuck in the housing?
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Horney
« Reply #2 on: 14 June 2005, 22:18 »
Cheers bud I'll have a look tomorrow when it's light!
Nick
Offline hockeylad72
« Reply #3 on: 14 June 2005, 22:40 »
bridge the two connectors together from the brake light switch, if you have lights - switch is fooked
Offline monzablue16v
« Reply #4 on: 14 June 2005, 22:56 »
Drove from Bodmin to Neqwuay with two bits of wire for a brakelight switch once!!!!!!
Offline Horney
« Reply #5 on: 17 June 2005, 09:31 »
Turns out it was just the 10amp fuse.
I'm surprised at the germans on this one. Surely putting the brake lights on a their own fuse is silly. Unless someone tells you they've gone, you'd never know. If you put the, on the same circuit as say the head lights you'd soon know the fuse was gone!
Nick
Offline GTI EDITION (aka LTD)
« Reply #6 on: 17 June 2005, 10:05 »
Nick
It maybe because the brake lamp circuits on VWs are wired to work even when the ignition is off where as the Head lamps are fed via the X relief relay (as well as the wipers, horn,heater fan and the heated rear window) :undecided: :smiley:
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
