Author Topic: sump  (Read 2009 times)
Offline Tazzy
sump
« on: 21 June 2012, 19:41 »
im having an oil change done this weekend as the car has never had one whilst ive owned it
but whilst im at it, im getting the sump resealed as well as ive got a leak
question is, is it a gasket or sealant?
cheers
If It Comes Off, Modify It!
Offline mar_k
Re: sump
« Reply #1 on: 21 June 2012, 19:42 »
No gasket on the sump just sealant, iirc its almost £20 a tube
Offline rio_gti
Re: sump
« Reply #2 on: 21 June 2012, 20:49 »
Get the pick up pipe done at the same time as the sump is coming off  :wink:
Offline cullygti
Re: sump
« Reply #3 on: 21 June 2012, 20:53 »
good advice that is  :cool:
Offline DunnDeal12
  • Limited
Re: sump
« Reply #4 on: 21 June 2012, 21:25 »
+1
Re: sump
« Reply #5 on: 21 June 2012, 23:49 »
:afro: well worth doing, only going to cost around £12 in parts and could save your engine in the long run.
Offline Tazzy
Re: sump
« Reply #6 on: 22 June 2012, 21:03 »
sorry for dumb question but what do you mean pick up pipe?
thanks
Offline cullygti
Re: sump
« Reply #7 on: 22 June 2012, 21:10 »
in the sump there is an oil pickup pipe its got a filter on it that can get blocked and starve the engine of oil resulting in a seized engine etc so worth getting it changed while the sump is off  :smiley:
Re: sump
« Reply #8 on: 22 June 2012, 22:56 »
thanks
A good thread on the subject here: http://www.golfgtiforum.co.uk/index.php?topic=193737.0
Offline dan2252
Re: sump
« Reply #9 on: 23 June 2012, 01:04 »
or if you dont wana change the pick up pipe just clean it out :) i changed mine as it was about a tenner for new pipe from vw
MK4 golf 1.8 turbo agu :)
