Hi, so after a quick flick through the haynes vague manual i tried to fit my new thermostat as it seems to be sticking open.
Didn't quite read the manual correctly and went straight for pulling the bottom rad hose off and then went to remove the thermostat but soon realised there is a load of power steering mouting bracket in the way. I loosened the bolts i thought were holding it on but im going wrong somewhere and need some advice.
This is what mine looks like - from the top
from the bottom
Can someone confirm the process to replace the thermostat on a 2.0 8v with powersteering and if possible identify what bolts come off from the photos above.
Thanks
Adam
