Author Topic: Road bike frame sizing  (Read 1754 times)
Offline Khare
  • The bear that khares
« on: 20 June 2012, 19:20 »
Just about to buy a road bike, and I have the choice of 53cm, 56cm and 59cm frame sizes. Going by this website I require a 56cm sized frame
http://www.ebicycles.com/bicycle-tools/frame-sizer/road-bike/size-sheet?utf8=%E2%9C%93&u=in&r=man&h=1803.4&i=825.5&b=Calculate
However according to this http://bicycling.about.com/od/howtoride/a/bike_sizing.htm I require the 59cm.
So which one is it?
5, 11"
Leg length 32"
VW BUSH
Re: Road bike frame sizing
« Reply #1 on: 20 June 2012, 19:53 »
Im the same size as you and I ride both
Offline Khare
« Reply #2 on: 20 June 2012, 19:55 »
Checked a 3rd website and it said 56cm, so will go for 56 size as I prefer my bike slightly bigger, for a longer stroke.
VW BUSH
« Reply #3 on: 20 June 2012, 19:56 »
 just checked and im riding a 58  :grin:
Offline Khare
« Reply #4 on: 20 June 2012, 19:57 »
Penes  :laugh:
56cm ordered now  :grin:
Offline Sam
  • Sam I am
« Reply #5 on: 20 June 2012, 19:59 »
So you went for the smaller option....
VW BUSH
« Reply #6 on: 20 June 2012, 20:00 »
What you bought?
I've dug my old Coppi out, and im well unfit :laugh:
Offline Khare
« Reply #7 on: 20 June 2012, 20:08 »
It's alright, 56cm is the size that keeps popping up the most.
http://www.cheapestbikesuk.com/viking-retro-road-2011-fixed-single-speed-bike-178
Went for this one. Not wanted to spend any more than £200 and after reading reviews it seems it's a decent bike for the money and for the type of use I'm going to give it.
« Reply #8 on: 20 June 2012, 20:51 »
It is a shame they do not show the top tube length etc, you may need a 53cm, 56cm is very big for a road bike.
Offline Ridg
  • TDI - Soot Happens!
« Reply #9 on: 21 June 2012, 12:16 »
I'm 6' 2", I ride an XL or 58cm, 59cm would have been far too big for you can you'd have probably struggle to standover the frame.
The larger frame would also have probably come with 175mm cranks, given you height and shorter legs these would have been slightly too large and potentially caused knee pain, your 56 should come with 172.5mm cranks.
If anything you'll probably want to adjust the stem as this will probably be too short for you, although will produce a slightly more relaxed riding position as a result.
