Author Topic: Best from a K03s  (Read 3088 times)
Offline Dalo Harkin
Best from a K03s
« on: 20 June 2012, 07:46 »
yet another thread, but wanted to get opinions
I am going to be fitting a K03s to my ARZ (currenly has a K03) other than the mods in my sig I also have these on my shoppin list but want to see if there are any benefits to upgradin other parts rather than the ones I am going to buy so:-
FMIC (the toyosports twin outlet one) with silicone or ali tubing it will be this http://www.ebay.co.uk/itm/190602884505?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 or a custom one
TIP (was just thinkin is it worth going for one with a 3'' MAF as opposed to normal
Lambda sensor need doing so will do that
Dont want to go the K04 route as I have already bought the K03s
so would I actually benefit from different injectors, different FPR, different fuel pump etc?
« Last Edit: 20 June 2012, 07:50 by Dalo Harkin »
Offline DunnDeal12
  • Limited
Re: Best from a K03s
« Reply #1 on: 20 June 2012, 08:00 »
whos doing the mapping? R-tech?
Offline Dalo Harkin
« Reply #2 on: 20 June 2012, 08:03 »
Probably Carbon Chiptuning  :smiley:
Offline DunnDeal12
  • Limited
« Reply #3 on: 20 June 2012, 08:06 »
custom mapping or generic map?
Offline Toby
  • Car - less
« Reply #4 on: 20 June 2012, 09:48 »
Id recomend r tech personally , niki knows his way around a 1.8t! Even more so with his new software  :evil:
Currently down under
Offline cullygti
« Reply #5 on: 20 June 2012, 09:49 »
another here for r-tech  :cool:
Offline Chris#101
« Reply #6 on: 20 June 2012, 09:53 »
Another happy r-tech customer here, they really know there stuff :cool:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline rio_gti
« Reply #7 on: 20 June 2012, 10:08 »
im gonna be going the same route with the intercooler, just gotta find someone with one to get the same pipework,
dont think it is necesarry with a k03s for a 3" tip,
wont need fuel pump, and i dont think injectors would make much difference either
get a forge actuator on it, and a dwnpipe and decat, and prob exhaust if you were thinking about changing it, also catch can would be a good idea, and n249 bypass etc...
what ever you do thou and think you might change do it befor the remap, as i learned that anything you do change will throw the map out ind it wont run too great...... thus me going the k04 route  :wink:
Offline DunnDeal12
  • Limited
« Reply #8 on: 20 June 2012, 11:34 »
if its a new turbo then its optional to fit a forge actuator, as the spring will be strong enough in the new turbo's actuator.
ko3s(odviously)
uprated intercooler is a must
2.5 or 3" downpipe is a must
cat back exhaust system(but i have known people to run standard exhausts and just down pipe)
If its a AGU/ARZ KO3s generic map then you wont need a FP, injectors & MAF. but if your going custom map then id say yes take a FP, calibra Yellow injectors, forge actuator(optional if you have new turbo), 3" TIP or 80mm-70mm reducers & vr6 or LCR MAF. to make the most of the mapping.
Offline Dalo Harkin
« Reply #9 on: 21 June 2012, 07:59 »
Thanks for the advice guys, It'll be custom map, the guys at Carbon have helped me out so would always go back there, the only way I would go R Tech is if Carbon were too busy to fit me in, they are VERY atm
Cheers all
