Author Topic: Lambda Sensor  (Read 1552 times)
Offline Dalo Harkin
Lambda Sensor
« on: 18 June 2012, 12:42 »
Do the 1.8T just have the 1x lambda sensor  :undecided:
I have been needing to do mine for a while and am getting everything else ready for the FMIC and K03s  :evil:
Offline Xtrhardcore
  • Mk3 Gti 2.0 8v MoreDoor
Re: Lambda Sensor
« Reply #1 on: 18 June 2012, 12:45 »
iirc i think it has one in front of the cat and one behind? could be wrong though  :embarassed:
Mk4 Gti - Gone but not forgotten!
Offline Dalo Harkin
Re: Lambda Sensor
« Reply #2 on: 18 June 2012, 12:46 »
mine is throwing one code, time to find out which is knackered then  :smiley:
Offline Granta Gti
Re: Lambda Sensor
« Reply #3 on: 18 June 2012, 13:54 »
Our ARZs have the 2 sensors. What's the code?
Offline Dalo Harkin
Re: Lambda Sensor
« Reply #4 on: 18 June 2012, 17:06 »
Cant remember the code it was picked up while getting it remapped and recommended to be changed and that was ages ago, car gets used about 100 miles a month if that so not that rushed for doing it
Re: Lambda Sensor
« Reply #5 on: 18 June 2012, 21:20 »
I have a AUQ and it has pre and post cat lambda sensors, easy to check have a look underneath floor just about in line with the seat and you will see a black box, see if you one or 2 wires going into it.
Offline shaft69
Re: Lambda Sensor
« Reply #6 on: 18 June 2012, 22:27 »
If looking for after cat one have one done 100mile bosch selling if req'd, Misdiagnosis so stuck with it.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Dalo Harkin
Re: Lambda Sensor
« Reply #7 on: 19 June 2012, 08:48 »
If you have 2 lambda are the front and back not the same fitting/type
Offline rio_gti
Re: Lambda Sensor
« Reply #8 on: 19 June 2012, 09:05 »
I had this problem they are both different they have different connectors on them too!!! And when trying to find the correct part no about 5 different ones come up!!!
Offline Dalo Harkin
Re: Lambda Sensor
« Reply #9 on: 19 June 2012, 13:33 »
Do you have the part numbers then or where you got them?
I only think that one of them is gone, so other than process of elimination findout out which has gone  :sad:
