Author Topic: 312 mm  (Read 4516 times)
Offline GTIANNIVERSARY16V
312 mm
« on: 17 June 2012, 11:44 »
Can you fit 312 mm brakes on the front?
Offline dubstar9
  • Back to the Golf scene
Re: 312 mm
« Reply #1 on: 17 June 2012, 12:01 »
Offline stainesy
Re: 312 mm
« Reply #2 on: 17 June 2012, 12:22 »
sorry to highjack but as its a brake size thread do annis come with bigger brakes than normal gtis? also what size is standered gti 8v front brake disc ment to be?
Offline sharki786
  • GOT BOOST??
Re: 312 mm
« Reply #3 on: 17 June 2012, 12:32 »
yes you can. If your gti is P plate or after it should have come with 288mm. Before P plate they came as 280mm and smaller. On all anni they are 288mm. If you want bigger brakes all you realy need is the 312 carriers a space plate made & 6mm longer bolts (if you braking is 288mm) it has been covered in the mmaintanance section have a lookie there.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline dubstar9
Offline stainesy
Re: 312 mm
« Reply #5 on: 17 June 2012, 13:03 »
ah right was just asking as i had my mates anni at mine yesterday and was going over it for him making sure all was well with it and i noticed his front discs were bigger than mine.
Offline Dan_GTi8v
Re: 312 mm
« Reply #6 on: 17 June 2012, 13:41 »
older gtis have 280mm :)
Offline stainesy
Re: 312 mm
« Reply #7 on: 17 June 2012, 14:03 »
Ah sweet. That clears that up then. Cheers
Re: 312 mm
« Reply #8 on: 17 June 2012, 14:04 »
Sweet, its a p reg anni.
My mates got the mk4 anni carriers, calipers discs etc.
Offline Dan_GTi8v
Re: 312 mm
« Reply #9 on: 17 June 2012, 14:20 »
if you want to use the mk4 calipers as well you will need some brake lines made up that have mk3 connections on 1 end and mk4 on the other. F17 BAD had some made up by a company called HEL cant remember what he paid now but it was pretty resonable
or just use the spacers on mk3 calipers as said above :)
