Author Topic: 312 mm  (Read 4517 times)
Offline lemski
  • 16v
Re: 312 mm
« Reply #10 on: 17 June 2012, 16:41 »
Ui can use a6 rear brake lines. Meet up perfectly on them.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: 312 mm
« Reply #11 on: 17 June 2012, 17:38 »
yeah i had the braided lines made up because i am running Audi S3 312 mm up front and the connectons on the caliper are different (dont see point in upgrading brakes and leaving rubber hoses their but theirs ways around it as said already - 288 calipers are the same as the 312mm calipers)
My original brakes were the 280mm as my car is early spec (Aug 1993 model)
Not no ordinary GTI....
www.mixcloud.com/kells/
Re: 312 mm
« Reply #12 on: 17 June 2012, 21:41 »
312mm will fit under 16"alloys all ok.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: 312 mm
« Reply #13 on: 17 June 2012, 23:12 »
Interesting, never heard this before.
Offline lemski
  • 16v
Re: 312 mm
« Reply #14 on: 18 June 2012, 08:59 »
Its for rear brakes obv. Just done rears on a mates mk2. Fronts u could probally find a vag that has the same lench hose to calliper
Offline sharki786
  • GOT BOOST??
Re: 312 mm
« Reply #15 on: 18 June 2012, 10:26 »
even under the BBS RX2's? As iv heard people had to grind the calipers down abit???
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Len
Re: 312 mm
« Reply #16 on: 18 June 2012, 12:54 »
IF people bothered to do a SEARCH!
You will find a very detailed thread on this subject in the info section :rolleyes:
www.sas.org.uk
www.the-ace.org.uk
Offline Ess_Three
Re: 312 mm
« Reply #17 on: 18 June 2012, 13:08 »
if you want to use the mk4 calipers as well you will need some brake lines made up that have mk3 connections on 1 end and mk4 on the other. F17 BAD had some made up by a company called HEL cant remember what he paid now but it was pretty resonable
or just use the spacers on mk3 calipers as said above :)
You only need to change the lines if you are changing from 280s.
288s have the same banjo connection regardless of whether they are Mk4, S3, TT etc.
..but gaining motorcycles.
Offline Ess_Three
Re: 312 mm
« Reply #18 on: 18 June 2012, 13:09 »
No they won't.
Some...not all.
They do NOT fit under 16" RXIIs without mods.
However, most single piece 16" wheels that aren't too deep on the dish, should be OK.
Offline tweed
Re: 312 mm
« Reply #19 on: 18 June 2012, 15:09 »
I think I would have problem fitting them because of my split rims. I have a 14mm spacer at front.
