Author Topic: going to change engine.  (Read 3782 times)
Offline simon_709
« on: 17 June 2012, 10:17 »
Hi guys, right I had my car re mapped on thurs and decided to take it for a burn down the a47, was so impressed with how different it felt all the way to 145mph, until the oil pressure light flashed and beeped at me, so I pulled off straight away but it was to late..the engine had heat seized :( so had to get towed home by a peugeot  :sick: 306 gti6 :(  tried turning it over by the crank and its solid..won't budge one bit.  I love the golf though and instead of binning it and getting another I've decided its gna be cheaper to just get another agu lump and drop it in. I was just wondering if anyone has a guide or any info if they have done this before?? Thanks
My Golf GTi, RS4 reps 17", coilovers, tinted windows, De-cat and middle box removed with 3" oval back box, stage 1 Revo re map, G60 flywheel/VR6 clutch, HID kit, Forge 007p,
Offline dan2252
Re: going to change engine.
« Reply #1 on: 17 June 2012, 11:10 »
think its going to be that your pickup pipe has blocked and by giving it a good thrash down your private race track killed it as it couldnt get oil around the engine quick enough. also if its starved the engine long enough what else could it have done?turbo could have been damaged too?
MK4 golf 1.8 turbo agu :)
Offline cullygti
« Reply #2 on: 17 June 2012, 12:34 »
naming roads and saying the speed is not a very good idea on a public forum that mr police officer comes on  :rolleyes:
on another note feel for you as i had my engine seize due to pick up pipe  :cry:
Offline simon_709
« Reply #3 on: 17 June 2012, 14:26 »
I saw a few ppl had said about the pick up pipe, is that deep in the engine somewhere?? Will give me something to check when I get another one, I am so gutted about it though but def not leaving the old girl, will just find another lump.
Offline simon_709
« Reply #4 on: 17 June 2012, 14:29 »
I did think about the turbo as well actually, is there any ways of checking it off the car?
Offline stfc_gti
« Reply #5 on: 17 June 2012, 14:42 »
2002 1.8T GTI AUM, Standard (not for much longer)
Offline simon_709
« Reply #6 on: 17 June 2012, 15:01 »
Lol that's very true! Didn't want to show off just fancied a blast as it was the first time I'd gone top end.
Offline Chris.
« Reply #7 on: 17 June 2012, 15:10 »
Swap is easy enough. Unbolt downpipe with 4 bolts, leave that loose behind engine.
remove pulley from power steering and undo 4 bolts on the pump - leave everything sealed.
Remove all wiring and put over to one side
Id take the shafts out with them sstill attached to the box, so undo the hub nut and 3 bolts on ball joint and swing struts out the way - shafts will hang down - undo 2x 13mm bolts on clutch cylinder and also the gear linkages, tuck up behind
support engine and undo all mount bolts
slide forward with front panel and rad off the car  engine is out....swap all the bits over onto new one
Click For Build Thread
Offline simon_709
« Reply #8 on: 17 June 2012, 15:15 »
That's very handy Chris thanks for that! Am I right in thinking you've done this before lol??
Offline Chris.
« Reply #9 on: 17 June 2012, 15:16 »
Done loads.  Can near enough do them with my eyes closed. I can have a engine in and running in under 2 hours.
