Author Topic: front subframe rear bushes  (Read 2645 times)
VeeDubGTI16v
« on: 16 June 2012, 13:48 »
mine need changing! (not the rear wishbone bushes, the ones behind just for the subframe), anyone done the job?
Had a quick search and mk1 audi tt ones seem to be the ones to go for. I saw a pic and they are in two bits so wouldn't need pressing in, whereas I believe the mk4 one's would. Is this correct?
also, can the subframe be lowered enough without having to loosen stuff like the rack?
cheers  :smiley:
Offline DunnDeal12
  • Limited
Re: front subframe rear bushes
« Reply #1 on: 16 June 2012, 13:56 »
the tt ones are crap, try polybush ones (44AT Front, Subframe to Chassis Rear Bush) http://www.polybush.co.uk/shop/538_Volkswagen
VeeDubGTI16v
« Reply #2 on: 16 June 2012, 14:02 »
can you elaborate?
my concern with that is with the mounts effectively being part of the rear engine mount, poly bushes will vibrate too much with the engine being a diesel. Same reason I went with the ths dogbone and not poly
Offline DunnDeal12
  • Limited
« Reply #3 on: 16 June 2012, 14:12 »
caused way to much cabin vibration under the floor tbh when pulling off as there nearly solid aluminium with a rubber edge, i have now the polybush ones and the drive is great.
VeeDubGTI16v
« Reply #4 on: 16 June 2012, 14:27 »
thought it would be the other way round!
it's hard to tell from the pic, are the poly bushes 1 or 2 piece? ie do they need pressing in
Offline DunnDeal12
  • Limited
« Reply #5 on: 16 June 2012, 14:56 »
theres 1 poly bush and metal rod that you insert into the middle.
VeeDubGTI16v
« Reply #6 on: 16 June 2012, 15:02 »
ok cheers, need pressing in then!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 16 June 2012, 16:39 »
TT versions of the bushes have been fine for me
VeeDubGTI16v
« Reply #8 on: 16 June 2012, 16:53 »
dunndeal, what engine is in your mk4? might be a diesel thing
Offline DunnDeal12
  • Limited
« Reply #9 on: 16 June 2012, 16:55 »
1.8t the vibration was horrendous.
what tt bushes have you fitted wazzer? mine were out of the roaster.
