Author Topic: low on oil...  (Read 2732 times)
Offline danyo
low on oil...
« on: 16 June 2012, 09:00 »
Hi Guys,
Last night i was on the way home, within a mile of my house the oil warning light comes on and tells me to stop. So i pull over and leave it for 5 mins or so. then decide to just cruise home.
As i got home, my car lost all power and started making a loud ticking noise, which doesn't sound good!
Any ideas on what damage may have been caused? Before i take it to the garage.
Cheers Dan
Offline Bandit127
Re: low on oil...
« Reply #1 on: 16 June 2012, 09:09 »
Top it back up with oil (to the right level) and start it up. If it still rattly it could be serious.
You might have got away with it though, so worth a try.
Offline danyo
Re: low on oil...
« Reply #2 on: 16 June 2012, 09:35 »
looks like i haven't got away with it :( do you know what parts would have been damaged?
Offline DubAndDubber
Re: low on oil...
« Reply #3 on: 16 June 2012, 09:47 »
Sound like your pick up pipe was blocked, should never ever drive it when the oil light comes on.
Mk5 Golf Gti 06'
Offline cobalt6700
Re: low on oil...
« Reply #4 on: 16 June 2012, 10:41 »
Loud ticking?
Probably the hydraulic lifters, maybe big end bearings.
Loosing all power because it was seizing up.
1993 GTI 8v 5dr matt black and green - the 'sh!tball rally car'
1997 GTI 8v 3dr metalic black - the daily driver
2002 3DR 1.8T AUM silver - the new daily
1993 Jeep cherokee 4L - the weapon :D
Offline rockmonkey69
Re: low on oil...
« Reply #5 on: 16 June 2012, 10:42 »
You really need to take it apart to inspect it for damage, scoring on the camshafts, tappets likely to need replacing, cam chain tensioner and probably the turbo (assuming you its a turbo engine you have as you failed to mention what engine it is) normally you would get away without damage done to the big end bearings and crankshaft, if it wasn't driven for long or hard with slightly low oil.
In terms of price, a set of tappets, assuming once again you have a 20vt engine cost me upwards of £400 for the part from VW this was a few months ago. For the cams you should be able to source a good condition second hand set relatively cheap. If you have a 20vt the cam chain tensioner and chain is likely to need replacing, price varies from non-vvt to vvt unit, but expect to pay upwards of £60 for a second hand vvt unit.
Offline richw911
Re: low on oil...
« Reply #6 on: 16 June 2012, 11:16 »
+1  :cry:
Offline danyo
Re: low on oil...
« Reply #7 on: 16 June 2012, 11:20 »
sorry yes, its the 1.8 20v turbo 180bhp auq engine. Just dropped it off at my mates garage so he can take a look, and let me know the damage, fingers crossed its not to bad!
Offline mcgee9t2
Re: low on oil...
« Reply #8 on: 16 June 2012, 12:01 »
as my mate has recently found out after driving his around for a month telling us its a faulty sensor...i told him i bet the pick up pipes blocked...he took it to a garage, the pipe had melted! so was blocked...whole engines f*cked.  :sad:
Offline cullygti
Re: low on oil...
« Reply #9 on: 16 June 2012, 12:02 »
that pick up pipe cost me a new engine as i had the dreaded oil light come on was 4 hours from home aswell  :cry:
