Author Topic: low on oil...  (Read 2733 times)
Offline barrym381
Re: low on oil...
« Reply #10 on: 16 June 2012, 12:05 »
that pick up pipe cost me a new engine as i had the dreaded oil light come on was 4 hours from home aswell  :cry:
the 1st thing i do after buyin a golf is drop the sump an change the pipe  :smiley:
Offline cullygti
Re: low on oil...
« Reply #11 on: 16 June 2012, 15:29 »
was the first golf i have ever owned so didnt have any knowledge of them what soever infact i didnt even like them  :grin:
Offline Dalo Harkin
Re: low on oil...
« Reply #12 on: 16 June 2012, 19:24 »
happened to me STOP came on drove very slowly home (about 10 miles) and then had the sump off and pick up pipe replaced etc...
Luckily I got away with it
Hope no serious damage is done, if its blocked then you adding more oil it would still sound tickety, replace the pipe and then see how it is
Re: low on oil...
« Reply #13 on: 16 June 2012, 21:07 »
Your going to need to be really lucky to have escaped causing any damage.
Offline Bandit127
Re: low on oil...
« Reply #14 on: 16 June 2012, 21:16 »
Wondering if the lack of power was down to pistons getting hot and binding in the bores.
I can't be the only one here who let a 2 stroke run out of oil in their teens and had it slow down and stop only to restart 10 minutes later - with piston slap aplenty. Scored bores and piston skirts was the result of that.
Offline mar_k
Re: low on oil...
« Reply #15 on: 16 June 2012, 21:35 »
so if you stop as soon as the light comes on would you have stopped in time to avoid damage
or is it too late by then
Offline DubAndDubber
Re: low on oil...
« Reply #16 on: 17 June 2012, 03:24 »
Well of the car has told you you to stop, and you did. Well done. If you driver on after the car has told you to stop, then well you are just stupid!
Mk5 Golf Gti 06'
Offline danyo
Re: low on oil...
« Reply #17 on: 18 June 2012, 11:02 »
bad news guys...... gonna need a new engine! well thats the cheaper option anyway! removed the sump and there was all sorts of bits floating around, metal, plastic etc. also took the head off and the cams are a mess!
it turned out the be the pick up pipe was blocked!
anyone know anywhere i can source a recon engine from? or any reputable breakers yards, that will give some sort of guarentee / warranty?
cheers guys!
Offline Granta Gti
Re: low on oil...
« Reply #18 on: 18 June 2012, 11:29 »
Sorry to hear this mate  :cry:
Offline cullygti
Re: low on oil...
« Reply #19 on: 18 June 2012, 11:31 »
try cooki on here he had an agu engine going cheap
or take the whole car if he still has it  :grin:
http://www.golfgtiforum.co.uk/index.php?topic=233418.0
