Golf mk3
hardmonkeys
is water ok as coolant for summer driving???
Topic: is water ok as coolant for summer driving??? (Read 1919 times)
Jasikasisback
15 June 2012, 23:43 »
how's about it folks...would like to know what you think...just wondering if i can get away with just h20 over the summer...
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: is water ok as coolant for summer driving???
15 June 2012, 23:55 »
No it is not. Coolant is not only antifreeze, it also increases boiling point and has anti corrosion additives.
Running on poor water is a BAD idea, use at least 1/3 coolant concentrate! Coolant is really not that expensive......
Bandit127
Here all the time
16 June 2012, 03:24 »
Took me ages to work out why my old mini used to eat water pumps. It was because I ran it on water during the summer - and anti freeze lubricates the bearing.
Having learned my lesson the hard way my cars have had a 50% mix all year round since.
Last Edit: 16 June 2012, 11:57 by Bandit127
search
16 June 2012, 09:51 »
should only ever use water if its life or death lol. aka broke down to get you to somewhere.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
CJA321
16 June 2012, 09:56 »
You can get Tesco value AF im sure....... That makes zero sence, ur causing urself even more hastle for the winter when you have to change it
MK3 GTI 20vt project
http://www.golfgtiforum.co.uk/index.php?topic=230628.0
Jasikasisback
16 June 2012, 11:02 »
I thought that only g12 type of coolant was reccomended. Didn't know tesco made compatible coolant.
itavaltalainen
Reply #6 on:
16 June 2012, 11:22 »
5L of G12++ compatible coolant only cost 15-20£ so just put in a 50/50 mixture - will save you trouble of changing again in winter.
If that's too much money then get a bike
leigh_harty
Audi AGU
Reply #7 on:
16 June 2012, 13:06 »
Plus water will leave the insides rusty
Dont lose your dinosaur!
Jasikasisback
Reply #8 on:
16 June 2012, 18:38 »
So this g12 is better than standard ethylene glycol? What makes it better?
itavaltalainen
Reply #9 on:
16 June 2012, 18:46 »
G12++ (G12 is obsolete and has been for a while already - as it is not compatible with G11!) is also ethyl glycol based but has more anti corrosion additives (like sodium benzoate, sodium nitrite etc) that prevent rust and chalk which allows for 5 year drain intervals rather than 2 years. Due to the increased amount of those additional additives it's also less corrosive to aluminium (the stuff your cylinder head is made of).
Golf mk3
hardmonkeys
