Author Topic: Navigation Directions  (Read 6560 times)
MonkeyP
« on: 14 June 2012, 22:45 »
I have recently noticed that when i use my navigation on my car the directions don't come up in the instrument panel display. is this normal or have i got a problem with my system?
Also tweeter keeps crackling which i know is not normal but have been told this is a common problem. is this true?
« Last Edit: 14 June 2012, 22:47 by MonkeyP »
Offline Edi35
Re: Navigation Directions
« Reply #1 on: 14 June 2012, 23:04 »
You should get directions on the MFD too, this worked on my CW GTI MK6 with the RNS510, no crackling either. Take it to your dealer.
Current: GTI Edition 35 Candy White 5dr DSG 19" Glendale, RCD510+DAB, Dynaudio, Storage Pack, Parking Sensors
Gone: Edition 35, GTI Mk6, Edition 30, GTI Mk4, GTI Mk3, GTI Mk2 and my favourite the UR quattro
For those that dont know DSG is an electronically controlled dual-clutch multiple-shaft manual gearbox
Offline ScottA
« Reply #2 on: 14 June 2012, 23:09 »
+1
Offline Mr GTD
« Reply #3 on: 14 June 2012, 23:57 »
+1
Yep sounds like a problem to me, dealer visit is in order...
Offline brown.jamesa
« Reply #4 on: 15 June 2012, 06:00 »
I get the Nav directions on mine MFD, I take it you have cycled though the MFD settings to toggle to the navigation pane?
Also I have no tweeter crackling, so I would go back to your dealers.
Current: Mk7.5 GTI PP (67)
Past: Mk6 GTD (12), Mk5 GT TDI 140 (54)
Offline sundaydriver
« Reply #5 on: 15 June 2012, 12:12 »
Have you retro-fitted the RNS510?, if so you have to code it with VCDS for them to work on the MFD.
« Last Edit: 15 June 2012, 12:14 by sundaydriver »
2012 Golf R, APR STAGE 2+, BCS power valve TB exhaust, loba HPFP, evoms intake, Rising blue, 19" Talladegas -BMW M2
Offline p3asa
« Reply #6 on: 15 June 2012, 13:12 »
Recently? As in it used to be there and no longer is?
Either way, yeah like everyone has said its meant to be there.
I much prefer the display on the MFD as it counts you down to junctions etc which can be handy when it is telling you to turn left and there are umpteen roads to turn left at  :smiley:
MonkeyP
« Reply #7 on: 15 June 2012, 13:27 »
Well as i have only had my car a month I have just found out that the previous owner retro fitted the system but didnt tell the dealer. They have offered to fix the problem. Also going to be very cheeky and ask them while they are fixing the problem can they throw in the handsfree bluetooth kit! lol
Offline Mr GTD
« Reply #8 on: 15 June 2012, 14:05 »
That is cheeky lol...good luck with that  :grin:
Offline Jimble
« Reply #9 on: 15 June 2012, 17:33 »
I think you might struggle with that mate cos to fix the nav issue only requires plugging a laptop into the car whereas fitting the bluetooth means taking quite a lot of the trim off including taking the stereo out.
Good luck!
