Author Topic: Navigation Directions  (Read 6561 times)
MonkeyP
Re: Navigation Directions
« Reply #10 on: 16 June 2012, 15:52 »
Have you retro-fitted the RNS510?, if so you have to code it with VCDS for them to work on the MFD.
Well as i have only had my car a month I have just found out that the previous owner retro fitted the system but didnt tell the dealer. They have offered to fix the problem. Also going to be very cheeky and ask them while they are fixing the problem can they throw in the handsfree bluetooth kit! lol
I think you might struggle with that mate cos to fix the nav issue only requires plugging a laptop into the car whereas fitting the bluetooth means taking quite a lot of the trim off including taking the stereo out.
Good luck!
Thanks everyone for the info.
They need to fix the tweeter as it should not be crackling but will see if they will install the bluetooth at a reduced cost. theres no harm in asking.
One last thing sorry to be a pain. are you able to search through the MDI track list on the MFD or is the only way to do it via the system?
Offline p3asa
« Reply #11 on: 16 June 2012, 20:51 »
Im sure but could be wrong that the official VW Bluetooth is fitted under the passenger seat so it would involve a lot of running wires etc to there and back to the head unit. I don't know if the loom is already present.  However 3rd party bluetooth units like the one I have "Fiscon" can be plugged into the back of the stereo and work the exact same way.
As for being able to search via the MFD, no. It only shows the song being played.
MonkeyP
« Reply #12 on: 17 June 2012, 00:49 »
Thanks p3asa i will definitely look into the Fiscon as would really help. is there anywhere specific you would advise buying it from or is it a google job?
Offline p3asa
« Reply #13 on: 17 June 2012, 11:58 »
There was also another one called mObridge doing the rounds that got an equally good write up. Both just pop down the back of the head unit without any issue.
I bought my Fiscon through a group buy on here and must say its been flawless.
You will probably find them on eBay or such like as bluetooth comes on the cars now. I know when I come to trade mine in I'll be selling it on there. Or have a look at the classifieds in here.
http://www.youtube.com/watch?v=kyCPk7T7sp8&feature=plcp has a video of it working.
It won't win "many" oscars as it was a 5 minute job while the Mrs was in the supermarket and I was bored protecting the car in the car park  :laugh:
MonkeyP
« Reply #14 on: 17 June 2012, 13:05 »
Well i have had a quick look at one on ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290725129837#ht_500wt_938
hopefully will win it and then the next problem is gettin it installed.
Offline Jimble
« Reply #15 on: 17 June 2012, 13:42 »
I would personally buy an oem unit and fit it behind the head unit, thats what i have and have just bought one off ebay for a friend, at least then the mic is hidden in the overhead light unit rather than on the A pillar. I paid £199 +£10 delivery.
Offline dubber36
« Reply #16 on: 17 June 2012, 13:48 »
The dealers will tell you that bluetooth cannot be retro fitted (other than that standalone touchscreen affair that they offer as an accessory) and to be fair, they are sort of right. Those of us that have retro fitted bluetooth have used a patch loom supplied by the third party, as none of the wiring comes installed the car unless it bluetooth was factory fitted.
Offline p3asa
« Reply #17 on: 17 June 2012, 22:09 »
You can hide the mic behind the overhead light unit with the 3rd party ones.
It doesn't matter which version the OP buys, he still has to physically run the mic up to there.
I have mine on the A pillar and never had 1 complaint. I personally don't know if I could be bothered feeding it all the way to the light unit.
Offline dubber36
« Reply #18 on: 18 June 2012, 08:03 »
It takes 5 minutes. Remove the grab handle (2 screws), the vanity light (pops out) and the overhead console (2 bits of clipped in trim and 2 screws). Thread a length of stiff wire through, tape the mic wire to the end and pull it through. Easy peasy.
Offline p3asa
« Reply #19 on: 18 June 2012, 10:42 »
You make it sound like a 2 minute job  :laugh:
