Author Topic: UPRATED ARB  (Read 2278 times)
Offline 1.6mk4GOLF16v
UPRATED ARB
« on: 13 June 2012, 15:01 »
i know its been covered on here alot but just need to be sure before i buy one so a few question
do i need a 22mm or 19mm bar? as ive noticed they come in different diameters
can i fit either?
any ideas what diameter the 1.6 mk4 comes with as standard?
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Offline rockmonkey69
Re: UPRATED ARB
« Reply #1 on: 13 June 2012, 15:23 »
No idea as to the standard 1.6 antiroll bar but the size you need is the size you choose to go for surely. I decided to go for Neuspeed 25mm front and rear antiroll bar and I am happy with the size. The antiroll bar is supposed to give more stability so it stands to reason that a thicker one would be better at the job.
Re: UPRATED ARB
« Reply #2 on: 13 June 2012, 15:28 »
yes agreed, but im not gonna buy a 23mm bar if its to thick to fit, its all a bit confusing as ive seen the skoda vrs bar (hoops underneath driveshaft) come in 2 different thicknesses  :undecided:
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
Re: UPRATED ARB
« Reply #3 on: 13 June 2012, 16:50 »
I'm not certain what kit your looking at but I would have thought the kit comes with the required bushes for the antiroll bar to make sure it's of the correct size.
My rear antiroll bar came with clamps, bushes, drop links, rear antiroll bar - all of the correct size to fit as you would expect from a kit. The fronts came with uprated bushes of the correct size as well - so as to accommodate the size of the antiroll bar.
Also my golf was a 1.6 to begin with, I replaced my 1.6 antiroll bars with 25mm front and rear antiroll bars.
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: UPRATED ARB
« Reply #4 on: 13 June 2012, 17:16 »
You will be able to fit most size front arbs...You will see when you come to do it. It 'clips' on the subframe and you then tighten them...so can fit big or small. Bushes should come with the kit you buy. Rear there is no restriction on how big you fit  :smiley:
Re: UPRATED ARB
« Reply #5 on: 14 June 2012, 11:30 »
cheers for that guys  :smiley:
not buying a actual kit, jus the arb of fleabay with the hoops that go under the driveshaft so i can take the front a bit lower  :cool:
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
Offline cullygti
Re: UPRATED ARB
« Reply #6 on: 14 June 2012, 11:32 »
how low you planning on going and are you using coilovers
Re: UPRATED ARB
« Reply #7 on: 16 June 2012, 19:13 »
very low  :wink:
yep got the fk coilovers in but scared to drop the front too much incase of rubbing
also i get a creaking noise when i turn left into my driveway, something to be worried about?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
VeeDubGTI16v
Re: UPRATED ARB
« Reply #8 on: 16 June 2012, 19:29 »
as long as the rear one is the same/bigger you should be well matched, but as you are going 'very low' you might as well remove the front one as you will ruin the handling anyway  :grin:
you can get a 28mm (neuspeed?) rear that would go very nicely with a 25mm front  :cool:
or 25mm rear eibach and r32 23mm front a bit more cost effective  :huh:
Offline cullygti
Re: UPRATED ARB
« Reply #9 on: 16 June 2012, 19:39 »
whats the ones on ebay with the hoops that go under  :huh:
