Author Topic: UPRATED ARB  (Read 2295 times)
Offline 1.6mk4GOLF16v
Re: UPRATED ARB
« Reply #10 on: 18 June 2012, 12:03 »
as long as the rear one is the same/bigger you should be well matched, but as you are going 'very low' you might as well remove the front one as you will ruin the handling anyway  :grin:
you can get a 28mm (neuspeed?) rear that would go very nicely with a 25mm front  :cool:
or 25mm rear eibach and r32 23mm front a bit more cost effective  :huh:
going low as i can on 19" rims, not sure how low that actually is in measurements though
 :cool:
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Re: UPRATED ARB
« Reply #11 on: 18 June 2012, 12:04 »
whats the ones on ebay with the hoops that go under  :huh:
skoda octavia
quick question does the bump in the middle of the arb go over or under the exhaust pipe?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
Offline DunnDeal12
  • Limited
Re: UPRATED ARB
« Reply #12 on: 18 June 2012, 14:34 »
skoda octavia
well if it goes over then id say your exhaust aint fitted right.
