Author Topic: Walbro or s3 fuel pump  (Read 4789 times)
Offline rio_gti
Re: Walbro or s3 fuel pump
« Reply #10 on: 13 June 2012, 17:26 »
Iv got. Walbro - woundnt bother tbh.
Seat leon fr is direct fit/s3 something needs blocking off.
Changing mine to a s3 one soon.
Mines running 3 bar fpr
On the s3 the second pick up needs blocking off because they have two pick ups as a result of their different fuel tank.
Also the fuel pump you want is an lcr fuel pump.
In addition, an inline pump doesn't pull air through - no more than your standard pump would because your standard pump will serve as a feed for the inline pump.
You can also modify the swirl pot relatively easily, there's a guide that goes into more detail on here. It works pretty well I might add.
so what your saying is i dont want the s3 pump as it needs a small ammount of modding what i need is the lcr one for a direct fit? (as i think i can get hold of an s3 one)
do they pump the same pressure? (ps i dont know if i will be using a 3 or 4 bar fpr)
Offline DunnDeal12
  • Limited
« Reply #11 on: 13 June 2012, 17:50 »
plus you can use a fuel pump from a auq 180 seat leon part number 8L0919051B or 8L0919051H they are also 4bar
http://www.seatcupra.net/forums/showthread.php?p=2391902
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #12 on: 13 June 2012, 22:02 »
I have a LCR pump in mine  :wink:
Offline rio_gti
« Reply #13 on: 13 June 2012, 22:20 »
easy to fit..... any messin??
Offline DunnDeal12
  • Limited
« Reply #14 on: 13 June 2012, 22:27 »
piece of piss :smug:
Offline Dave_IOW
« Reply #15 on: 13 June 2012, 22:48 »
LCR pump needs nothing blocking and is 4 bar..
Jaime16v made a guide about fitting a cheap 255lph pump into the standard arrangement and think he was really happy with it..  :smiley:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline rio_gti
« Reply #16 on: 13 June 2012, 22:51 »
sweet, might have a little look for that :afro:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #17 on: 13 June 2012, 22:54 »
apart from spilling petrol on the carpet under the seats, no hassle at al and a straight fit
Offline Dave_IOW
« Reply #18 on: 13 June 2012, 22:55 »
And getting a very light head with the tank lid off!
Offline rio_gti
« Reply #19 on: 13 June 2012, 23:06 »
nothin beats a legal high!!!!
might wait for a lcr one to come up as im not in a rush... although i WANT it done now!!!!!
