Author Topic: Walbro or s3 fuel pump  (Read 4790 times)
Offline rio_gti
« on: 13 June 2012, 00:01 »
For upto 300bhp what would be better/ easier to fit
Any advice welcom!!!
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Walbro or s3 fuel pump
« Reply #1 on: 13 June 2012, 00:22 »
Ask Toby. 4bpfp should do it IIRC.
Offline Toby
  • Car - less
« Reply #2 on: 13 June 2012, 07:15 »
Iv got. Walbro - woundnt bother tbh.
Seat leon fr is direct fit/s3 something needs blocking off.
Changing mine to a s3 one soon.
Mines running 3 bar fpr
Currently down under
Offline rio_gti
« Reply #3 on: 13 June 2012, 09:14 »
Why not with the Walbro, bro?
Offline DunnDeal12
  • Limited
« Reply #4 on: 13 June 2012, 09:30 »
walbro 255lph is way to much hassle to fit to a in tank pump, what about a in-line Fuel pump
Offline Toby
  • Car - less
« Reply #5 on: 13 June 2012, 16:16 »
Pulls in air  :huh:
Offline rio_gti
« Reply #6 on: 13 June 2012, 16:30 »
so then, is it the s3 pump or leon then.... if the leon is a direct replacement.......
Offline Toby
  • Car - less
« Reply #7 on: 13 June 2012, 16:32 »
leon direct fit. i think  :huh: :grin:
Offline jonrandom
« Reply #8 on: 13 June 2012, 16:50 »
Pulls in air  :huh:
It aint to much hassle to fit in it the fuel tank just got to make sure you make the hole smaller on the swirl pot to the fuel cant get away to fast!
Offline rockmonkey69
« Reply #9 on: 13 June 2012, 16:59 »
On the s3 the second pick up needs blocking off because they have two pick ups as a result of their different fuel tank.
Also the fuel pump you want is an lcr fuel pump.
In addition, an inline pump doesn't pull air through - no more than your standard pump would because your standard pump will serve as a feed for the inline pump.
You can also modify the swirl pot relatively easily, there's a guide that goes into more detail on here. It works pretty well I might add.
« Last Edit: 13 June 2012, 17:02 by rockmonkey69 »
