Author Topic: IT' fixed i think----- sorry for all the posts but please read this one  (Read 2620 times)
Offline rageraver
hey guys, wat a bodge my new car has been, was out lookin around and i noticed that the atuator was set to hold the wastegate half open?? i adjusted so it hold it shut. now car is flying from around 2300rpm the turbo hits and pulls like a mother,
all i need to no is what shud my peek boost be..... it went up to a tad over 20psi when i floored it in second but it drops down to like 19psi, in 3rd it did the same peeked a little then droped down, didnt hit a fuel cut but just wanted to make sure im not going to hurt anything...... as i have no dump valve it makes a nice turbo chatter.... i here this is bad (yeah??) so going to take it steay intill i get a recirc.
also behind the cover for the sunroof switches ive found a box with vortex on it and a race flag, has 3 wires one looks like a phone line sort of wire and it has a little adjuster on it..wat is this
Offline rio_gti
how did you notice that by 'looking around' lol
get a pic up easier to see
Offline james2
  • No scammers please.
Why no DV lol. It will lag bad /mine did when it failed . Loved that noise (chatter) until i found out it shouldnt.  :grin:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline cullygti
the box with vortex on is the alarm and the adjuster is the sensitivity i think i got the same one on mine
Offline rageraver
thats ok then, i was looking round trying to find faults and noticed alot of play in the actuator arm so i backed the back nut and the wastegate arm slid back , what about the boost psi?? is that to high?? proper goes now lol
Offline rageraver
no dumpvalve as i had atmospheic one on, so took it of after reading on here... just gotta get a good recirv valve
Offline cullygti
is it mapped and what stage if it is
Offline rageraver
not sure if mapped but running a few mods as in other posts
Offline cullygti
if it aint then it sounds a bit high to me stage 1 still sounds high stage 2 fook knows  :laugh:
Offline JimBR
The amount of boost is about right but id be worried its not fuelling right for it and it might run lean. Get it to R-Tech once youve got a DV and let them check it over and map it properly  :smiley:
« Last Edit: 12 June 2012, 21:59 by JimBR »
